OK drained the trans?
Old 04-24-2010 | 11:41 AM
deerebill's Avatar
Default OK drained the trans?
In the process of changing the trans fluid and filter,on the drivers side of the trans is two lines that I think go to the cooler and my first question is what one is the return, the upper or lower one. I had thought about pumping the new fluid through the cooler into the trans. Can any one tell me what threads are on the end fittings of those two lines they are the same. Also is there a drain bolt in the torque converter?
Bill
98/XJ8 VDP
Old 04-24-2010 | 11:46 AM
test point's Avatar
Assuming a ZF 5HP24 transmission I think there was a torque converter drain for a couple early years that quickly went away.
Old 04-24-2010 | 01:31 PM
deerebill's Avatar
Sorry, I should have said the line on the left or right side!!
Old 04-24-2010 | 03:01 PM
deerebill's Avatar
Also how to break loose those #**? star bolts that hold the pan on (broke two T27 sockets)
Bill
Old 04-24-2010 | 05:55 PM
steve11's Avatar
ud
Are you changing the fluid in the 98 VDP?
Old 04-25-2010 | 09:46 AM
deerebill's Avatar
Yes! sorry should have said that.
Bill
RaceDiagnostics
04-04-2016 04:00 PM
n2audio
17
10-09-2015 10:53 PM
Manjag
10-01-2015 05:34 PM
mrplow58
09-30-2015 08:56 AM
Quick Reply: OK drained the trans?
