Opinions wanted for these or other rotors
2000 XJR
SP Performance Slotted Rotors (Pair) Brake Rotors for your 2000 JAGUAR XJR-S - TopBrakes.com
Decent rotors -or- what would you do?
Opinions please: I promise my feeling won't be hurt
2000 XJR
Couple of notes:
The link is for the rear and since the rear do very little braking, "cheap" rotors are OK.
Slots/grooves are OK, cross drilled is not.
I love their "distance to a full stop" graph
Did you notice the distance.. 20 and 30..... feets!!!!!!
Must have been a braking test from 5mph. Lol
Rotors are not a very high tech parts so, as long that the metal/casting used is of good quality, you will have no issue.
Couple of notes:
Couple of notes:
Curious.. what is "custom hi spec lightweight rotors" ?
Are we talking 2 pieces rotor with an aluminum hat?
And, worth adding, removing 8.5 lbs of rotational weight is something like the same as 34 lbs of dead weight, so x 2 = the same as removing 68 lbs from the car, so if my calculations are remotely correct, that would shave .068 seconds off a 1/4 mile time, or about 2/3 of a car length at the end of 1320 feet.
WinterJag
16
10-09-2015 07:49 PM
