overflow spills out when car is off
Received 2,263 Likes
bigj210 (05-19-2011)
Maybe the coolant expansion tank lines are crossed. One is the air bleed to the radiator and the other is to the atmospheric catchment tank. The lines will swap and the pressure side of the tank will drain into the atmospheric catchment tank and the air bleed line will purge to the wrong side of the coolant cap. I have seen this before.
Just a thought.
bob gauff
Just a thought.
bob gauff
bigj210 (05-22-2011)
the lines seem like they are correct. the top line comes from the radiator to the expansion and on the side of the expansion goes to the tank on the bottom. right before it releases the coolant and it spills out,the lines are hot and i can hear the radiator and expansion tank boil up. i have changed thermostat,and water pump. dnt know what else to do.
bigj210 (05-23-2011)
No problem!!
I actually had to save the shop foreman's butt on this one. When the X308 came out in the late 90's he did some work on the 'NEW CARS' and crossed the lines. He went home for the day and the customer came back after hours with coolant spilling everywhere. I looked and sure enough the lines were swapped. I put them back correctly and told the customer that it was probably an air pocket in the system. No charge to the customer (warranty) no penalty to the shop foreman (he owed me after that one) and no charge to Jaguar Warranty for the 'come back'.
I NEVER made that mistake because someone else did it for me and I learn from others
Experience is the best teacher!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
bob gauff
bob gauff
Nati
05-16-2020 08:30 AM
SingBlueSilver
08-27-2015 02:20 PM
Vector
US Lower Atlantic
08-26-2015 05:36 AM
