Overheating mystery resolved at long last...
Also the s/c produces a lot of heat under load, not so much at idle. So, if the s/c loop is not working correctly, the symptoms I would expect would be heat soak (reduced power after some spirited driving) and very hot intercoolers. This is easy to try, go and do some driving and high-power pulls, then stop somewhere soon after, doesn't have to be immediately but fairly soon. Give it a bit of gentle driving to let the intercoolers do their thing. If your intercoolers are too hot to touch after you stop then the s/c loop isn't cooling very well.
I don't believe that would cause the engine coolant temp to rise significantly at idle, especially in conjunction with a/c running.
Thanks everyone for your input, I've now got to the point where it seems I can rule out:
I wonder if the [authorised] Jaguar service centre would have any better luck trying to figure out what's going on?
- New Radiator
- New Waterpump
- New Thermostat
- Auxilary pump
- SC pump
- Replacement second-hand fan assembly
- Coolant loss
Okay, so I thought I'd start a new thread on this as it may help anyone else that is having unusual problems, for reference, here's the original thread:
https://www.jaguarforums.com/forum/x...placed-174335/
After battling overheating issues with my XJR and almost giving up - I decided I'd make the big 1.5 hour trek from one side of Sydney to the other - I booked my car in with Dr Jag (https://www.parsonsmotors.com.au/)...
The last straw was returning from Summernats last year when it was 46*C and my car was overheating while at 100+ km/h on a motorway....but that's neither here nor there...
So...it seems that when my car fans had been checked prior they were both spinning. When the car hit 95*C the fans switched to the full-speed - a quick inspection would also show both fans spinning away.
But were they? When the fans are on half-speed they operate in series (a fused circuit) but when they switch to full-speed they go into parallel (each fan has a different circuit/fuse). One of these fuses had blown. So, within a few minutes of switching to full-speed one of the fans would gradually slow and stop. The engine would then begin to overheat.
Seems so simple...why was this so hard to resolve? I don't know how other mechanics missed it. It cost me a fortune in repairs...and the final result - a fuse worth a couple of bucks. A bitter-sweet victory :-)
Troy.
Troy.
This saga began when something from the road ricocheted into the fan assembly, dislodging the frame and causing one the fans to jam - I suspect this is what may have blown the fuse too.
#30
#31
Received 13,089 Likes
JagSter63 (01-26-2019)
#32
slburns538
51
08-16-2019 10:49 PM
StrateLoss
37
06-17-2010 01:07 PM
