Oxygen Sensors Code P1646 2001 XJ8
The DTC changed for later engines- JTIS defines this as
P1647 ECM HO2S control malfunction –B bank, upstream
– Inhibits B bank upstream HO2S operation
HO2S heater failure
HO2S sensing circuit short circuit to ground or high voltage
HO2S sensing circuit open circuit ECM failure.
Which means the B bank (US drivers side) upstream sensor heater circuit malfunction. I would test the heater voltage at the sensor, then the heater resistance before replacing the sensor.
According to the JTIS reference above, the fuel trim is disabled, so I suspect you will see performance and gas mileage improvement if it is fixed.
P1111 only refers to the drive cycle status- Dont worry about it.
HO2S heater failure
Jimmy:
I have found that if you look at Alldata, compare it with whats on here, and with JTIS - and it all matches, you MIGHT have the right information. But is sure is a crap shoot. For instance, the discussion on a bunch of threads over the last several months about cylinder numbering, which you would think should be pretty straightforward. Also, with JTIS, you need to look at the first year of a particular model or engine series as well as the year in question, and be careful to note the vin numbers after a search. As an example, if you search MY 01 for DTCs the JTIS search results will show the results starting at MY 98 but will give VIN number ranges.
OK my friends. What a Trip. So i was able to replace the upper O2 Sensor. Not an Issue. The lower O2 Sensor is Hell tried to use a O2 Sensor Socket and was not able to get it out!!! Any Tip or Tricks on how to get to it? And let me ask Bank 1 is the Passenger Side RIGHT. Thx for the Help on this ya all
I was able to remove the OS in the cat with a thinwall OS socket. the 1st one I bought would not fit inside the Bung. With the right socket, and some PB Blaster, it came out but it took a long breaker bar. I had the luxury of removing it them with the cats out of the car because I installed new high flow cats from Nameless Performance
Good morning. Getting the P1646 code on our 2001 XJ8 with Restricted Performance light (nothing flashing).
I removed that plastic top center cover, the one up against the firewall, and looking straight down on the passenger side, the O2 sensor causing the P1646 is right there coming off the manifold and terminates with a gray plug? There is another sensor directly below that one that looks to be more difficult to get to.
My question is this. Can I test the sensor with a multimeter in some way before I purchase a new one? How do I know this particular sensor is the defective part? There are 4 sensors, 2 upstream and 2 downstream on each side. I hope I don't need to replace one on the drivers side. Looks to be buried pretty good.
I've read all the previous posts , and thank you to all. It helped a great deal already. And forgot to add...when I took off the plastic cover, it has a half turn common screw head fastener. Well.....the bottom half fell off. There is a tab it secures to. Maybe just add a nut plate there.
Thanks, Tim
Thanks, Tim
KarimPA
09-03-2015 07:32 PM
