Oxygen sensors replaced but still rough idle
Old 04-03-2022 | 06:12 AM
EscapedApe's Avatar
Default Oxygen sensors replaced but still rough idle
My 2001 XJR started to smell a little rich (to say the least) and I discovered two fault codes (P1646,P1647). I took it to my mechanic, who is very experienced on Jags from this era, who replaced all 4 oxygen sensors. Both fault codes were rectified. He said the sensors were black with soot - which he'd not seen before.
The car is running a little rough when idling (in any of PNDR), more so when it warms up I've noticed. My mechanic has said that it's not possible to reset the ECU on this particular year XJR so it will just need to learn and adjust. It's been three weeks now and it still has regular erratic idling.
Can it take this long (at least 200km driving motorways/city) for the ECU to retrain with the new sensors?
Obviously I'll get back in touch with my mechanic but just wanted to see if anyone had any sagely advice
BTW: I can monitor the sensors via my Torque app but am not really sure which to look at The app has 8 sensors, not all of them are showing activity, and each sensor has:
  • Wide Range Current
  • Voltage
  • Wide Range Equivalence Ratio
  • Wide Range Voltage
Old 04-03-2022 | 09:46 AM
JagV8's Avatar
Have you got (pending) P1000 or P1111?
If P1000, many codes cannot flag so you may end up guessing...
Old 04-03-2022 | 09:51 AM
RJ237's Avatar
Check the fuel trims, you may be running too rich or lean.
Old 04-03-2022 | 01:52 PM
Vauxi's Avatar
Ecu is possible to reset. But you need ids for it. It wil adjust itself back to normal state in couple drive cycles. Unless there is fault(s) of course.
Old 04-03-2022 | 09:22 PM
EscapedApe's Avatar
Hi Vauxi, are you 100% sure about that? My mechanic used to work with Jaguar in the UK when these models were released - and he said that this particular year/version ECU it was not possible to reset.
Old 04-03-2022 | 09:23 PM
EscapedApe's Avatar
There are no fault codes.
Old 04-04-2022 | 02:59 AM
JagV8's Avatar
These cars always have either P1000 or P1111. If your tool doesn't show either, change tool or its settings.
Old 04-04-2022 | 03:21 AM
EscapedApe's Avatar
Oh, I see - these codes [put very very simply] mean pass or fail, but it has to be one or the other? I just use the Torque app with the OBD2 but my mechanic has said there are no fault codes showing when he scans it.
Old 04-04-2022 | 07:34 AM
xalty's Avatar
you can flash program them with the right tools but the only day to day task you need is to pull the fuse/unplug battery to reset your trims.
Old 04-04-2022 | 08:30 AM
David N. Warner's Avatar
If the spark plugs are new and especially if they are iridium plugs, you may have a vacuum leak. Check the plastic hoses that go to the throttle body and the manifold under the throttle body. Also, check your oil cap gasket. High fuel trims will be a sign of vacuum leaking and these cars are very sensitive to this problem. Make sure the little hole under the plastic hose on the oil fill side valve cover is clear as well.
Old 04-04-2022 | 08:37 AM
One of my 2000 VDPs had a skip when idling at operating temp. The car would do this especially if in drive while stopped by the brakes. I did a lot of fooling around with no avail until I swapped all the coils from my other car and then the problem moved to the other car. Then I swapped coils until i located the faulty one and replaced it. When measuring the faulty coil with an ohm meter, it had similar readings to any other coil so I did not expect the coils were the problem. I also had a rough idle problem some time back that turned out to be a crack in one of the plugs.
Just a thought....
Old 04-04-2022 | 05:35 PM
EscapedApe's Avatar
Thanks everyone for your comments, just in case it wasn't clear - prior to the oxygen sensors being replaced, the car [while running rich] idled very smoothly without any coughs/surges
Old 04-04-2022 | 07:47 PM
RJ237's Avatar
But it's likely the air intake system was removed when replacing the sensors. At least look for cracks in the accordion section.
EscapedApe (04-05-2022)
Old 04-05-2022 | 02:53 AM
JagV8's Avatar
P1000/P1111 are status codes, confirming the state of the OBD monitors (you can read those instead but it's quick to see which of P1000/P1111 is there).
They're not fault codes (in this case) - any P1xxx code on any car is non-generic i.e. the car maker can have them mean absolutely anything (so you need to look them up in that car's info, which in this case you can download free from this site or JagRepair.com - Jaguar Repair Information Resource).
Old 07-01-2022 | 08:08 PM
EscapedApe's Avatar
Okay, so and update for anyone interested
After being away and too busy to get this looked at, I'm booked in to have it checked by my mechanic on Monday.
Worryingly, he made this comment:
Okay I think it’s the catalytic converters. Will run some tests and see what happens.
I said something like, wouldn't be a big coincidence if a problem developed with the catalytic converters at the same time the oxygen sensors were replaced?
The reason I’m thinking cats as when the oxygen sensors die it can default to rich settings and possibly block a cat.
...hopefully it's something simple ​​​​​​​
Old 07-02-2022 | 08:23 AM
Vauxi's Avatar
I'm not 100% sure but my yo2000 xjr was possible to reset via ids. Sorry for delayed answer.
Old 09-27-2022 | 12:08 PM
JamBar's Avatar
Hi, did you get this fixed? I have he same kind of issue after an O2 sensor change.
Old 09-28-2022 | 04:12 PM
JagV8's Avatar
It's quite a long thread with multiple things raised - so which exactly apply to your car?
Common issues include using the wrong sensor type or replacing the wrong one...
Old 09-28-2022 | 04:54 PM
Jhartz's Avatar
Timing chain tensioners (slipped timing) often cause a rough idle.
Old 09-28-2022 | 09:34 PM
02VDPMiami's Avatar
Using aftermarket O2 sensors can also cause rough idle. I replaced mine with eBay sensors and they were garbage, ran way worse. I swapped back in my old ones and the rough idle went away.
Jhartz (09-29-2022)
Quick Reply: Oxygen sensors replaced but still rough idle
