P0102 and Restricted Performance. Need help!
Hello All,
I was driving down the road, minding my own business, when....
I felt the car have a small stumble, then the dreaded restricted performance came on. The car ran fine, but is in restricted performance mode.
I searched and found that the code 0102 was something to do with the MAF, so I:
Cleared the code, it instantly came back
I swapped back to my original/stock MAF, still got restricted performance
so I then did a hard reset (touching battery cable for 15 seconds), and restarted and the restricted performance is still on. Tried clearing the code, came back.
I'm confused and need a little help.
I have swapped back to original stock and did a hard reset, but the restriced performance code persists.
Any suggestions?
Any suggestions?
WaterDragon (05-14-2013)
Update,
Checked connector, all wires intact. Still getting p0102
I may take it down to my local indy mechanic tomorrow and see what they find. I am no mechanic.
No matter what, it will get fixed, one way or another.
I'll report back when we've found the cause and fixed it.
Ignore the connector in the left in the photo, that was the one for the up graded 92mm MAF, the one I am holding is the stock one.
etachu (05-19-2013)
Used Air Mass Meter for A Jaguar XJR 99 03 and XKR 2000 2002 | eBay
Anyone else chime in if I'm wrong, but I think the XJ and XJR uses the same MAF
Johnken
09-22-2015 03:53 PM
