P0117 code, 2002 sport
Old 12-31-2017, 12:45 PM
Z07Brandon's Avatar
Default P0117 code, 2002 sport
I was fixing a small coolant leak and got everything buttoned up just now. I know the code is engine coolant temperature low curcuit input. Made sure that I connected it tight, and yeah. It clicked and is locked in place. The coolant temp gauge is working, it's not in a stuck position.
Any ideas?
Old 12-31-2017, 01:05 PM
Lady Penelope's Avatar
Received 1,386 Likes on 1,090 Posts
Reset code ? Otherwise it may reset itself after a few cycles . As long as it it reading
Old 12-31-2017, 01:25 PM
Z07Brandon's Avatar
Thanks. I'll reset it and go from there. Then this started leaking
Only thing I can think, is the clamp is not on correctly. Or not tightening fully.
And this is hose is new. Replaced it July 2017.
And this is hose is new. Replaced it July 2017. Oh, happy New year guys!
Old 12-31-2017, 01:28 PM
Corrosion under the hose or the hose too big to clamp as the hardware only has a fixed " pinch bite " ?
Old 12-31-2017, 03:03 PM
RJ237's Avatar
Received 2,801 Likes on 2,236 Posts
I had to switch to screw clamps a couple of times on my older cars, maybe tired spring clamps.
Z07Brandon (01-03-2018)
Old 12-31-2017, 03:23 PM
Sean B's Avatar
Received 1,357 Likes on 1,068 Posts
+1 on the screw clamps. I would also flood WD40 or similar to the sensor and it's loom connector to chase out oxidization. Then do an OBD reset.
Old 12-31-2017, 04:28 PM
Z07Brandon's Avatar
Perfect guys, I'll do that! It'll have to wait though. Currently 25 degrees Fahrenheit in Dallas
Old 12-31-2017, 05:17 PM
My kitty has icicles hanging from her . Will be - 8 F overnight .
Old 01-02-2018, 11:11 AM
Z07Brandon's Avatar
I'm thinking this is it. I was hoping letting it since Sunday would've helped the clamp get a tighter bite. But no luck. It still leaks. Dumb question quys. Should only use a srcew clamp on the side that is leaking? Or do both?
Old 01-02-2018, 11:53 AM
Doesn't mater as long as not too tight on plastic
Old 01-02-2018, 12:24 PM
Highhorse's Avatar
Received 1,795 Likes on 1,317 Posts
I'd be sure to run a wire brush and/or some sand paper around the neck to clean it up. As LP said regarding the possible corrosion. Be sure to also check the inside of the hose in case the neck has a burr on it and possibly scarred it.
Old 01-02-2018, 01:39 PM
Z07Brandon's Avatar
I will do. Lets see if I feel compelled to take it apart again in the 23 degree weather. It's easy, but I hate the cold.
Old 01-03-2018, 05:03 PM
Z07Brandon's Avatar
Switched them to screw clamps, and made sure not to over tighten. Let it warm up in the drive way, took it to the car wash to give it a quick rinse. Didn't see any leaks! I'll keep an eye on it though. Hopefully I have time this weekend to give the car a good detail.
The following 2 users liked this post by Z07Brandon:
Highhorse (01-03-2018), RJ237 (01-03-2018)
Old 01-03-2018, 05:05 PM
Z07Brandon's Avatar
I did that with some electrical contact cleaner. Reset the light, went for a drive. No more light! Thanks everyone
twmotox
08-11-2017 12:07 PM
Delirious
10-21-2015 08:11 AM
lunaticpro
03-18-2015 07:09 PM
pantheon
11-03-2009 01:23 PM
DaveM
10-22-2009 03:52 AM
Quick Reply: P0117 code, 2002 sport
