P01313 with Bank 1 misfires
P1313 with Bank 1 misfires
I have a 2002 XJR that has 150k miles on it. I had been driving the car for the past week or so and it ran perfectly fine. Yesterday, the car's fuel level got low enough that the fuel light came on, so I stopped to fill the car up. After leaving the gas station, I drove the car for maybe 5 miles at most and it seemed to still be running fine. I stopped at a red light and noticed the engine was idling rough. When I got home, I pulled the codes and only had a p0300 code. After giving it some time, I restarted the car, shut it off again and pulled the codes again. This time I had p0301 and p0304 in addition to the p0300. I replaced spark plugs on all cylinders with new NGK BKR6EIX-11P Iridium spark plugs and also swapped out the coil packs on cylinders 1 and 4 with new ones, cleared the codes and started the car again, but the problem was still there and the car had codes for p1313, p1314, and codes for misfires on all cylinders. After checking battery and electrical connections then and restarting the car, I'm now I'm getting p1313 with codes for misfires on all cylinders in bank 1.
Where should I start? Any help would be greatly appreciated.
Brian
Brian
After starting the car today and checking the codes, I'm now getting p0300, p0301, p0302, p0303, and p0304. I'm still not sure what to do. In addition to everything mentioned in the original post such as changing plugs and coils, I've also changed the fuel filter and did my best to inspect the tensioners on bank one. The car has the metal tensioners with plastic at the points where they connect with the chains. The tensioners looked fine and there seemed to be almost no play in the chain, so I'm not sure if that's a good thing or not. Still completely confused about this problem.
Jhartz (09-08-2021)
Thanks for the suggestions, y'all!
Did your car also have restricted performance and the blinking check engine light? When I let mine idle, it doesn't show restricted performance. After I rev the engine, the check engine light starts blinking and it goes in and out of restricted performance mode. I've been hesitant to drive it because of that.
No it never went into restricted performance. But I have had that like many of times as I have 11 of these things xj8s... do you have a compression gauge? To rule out any other problems the car has 150,000? It’s an easy thing and it lets you know where you’re at. Whenever I do a compression test it’s like I’m going to the Ground Zero and starting from the beginning
Might want to check for a vacuum leak. Dirty injectors too.
Running the fuel that low isn't a good idea either. May be unrelated but you can suck up some crap off the bottom of the tank that way and starve the injectors too.
Are all the cylinder specific misfires on the same bank?
+1 Fuel pressure; might change the fuel filter. But grab a wiring diagram for the ignition system. Years ago an XK8 owner had the same issue -- everyone (watashi wa included) jumped on secondary tensioners, which is nearly always the problem -- but it wound up being a loose connection effecting all coils, maybe in the fuse box on the port fender.
RJ237 (09-13-2021)
I wouldn't rule out clogged/malfunctioning cats. Especially with the high mileage. The fact is started on 1 bank only lends to this possibility. Then the other went?
I would rule it out before driving it much more. Cats can destroy an engine real quick. That's why mine are going bye bye. Way more trouble than they're worth.
Does the CEL flash when this happens?
Unless there's one connection that serves all 8 injectors, a loose connection is unlikely. It has to be something that can affect all cylinders randomly or 1 bank of cylinders randomly.
I'll try briefly running the engine with the upstream O2 sensors removed to see if that clears up the problem. That should tell me if the cats are bad, right?
