P0328 Knock Sensor Error Code
So my check engine light is on, and have the generic "P0328 knock sensor 1 circuit high bank 1 or single sensor" code error.
I also have the "Jaguar P1111 intake air temp sensor circuit intermittent high voltage code" error.
1) I am assuming the P111 is nothing to worry about?
2) I'm assuming the P0328 will have to be addressed?
3) I think I am correct that the error indicates that it is the knock sensor located on the right-hand side of the motor, as viewed from the driver seat?
4) I have read jimlombadi's excellent forum post on the knock sensor replacement, but cannot find knock sensors at the low prices he quoted all those years ago...........all I can find are in excess of $100.00 Anyone know of cheaper options? (part W0133-1655837)
5) I am using a Cent-Tech OBDII and would like to clear the check engine light, but am cautious when warned that doing so will erase dct data and freeze frame data............is this something I should not do? Or is it okay to erase the codes?
All input greatly appreciated.
Carnival Kid (03-16-2018)
Thank you KC, I just read a post by jagwhiting from 2014 that also supports the SU7012 usage, and o a post by member blurdg too, so maybe I'll go that route
With the recent work you've carried out, maybe a re-seat of the connector will get a better signal. You can test the KS with a multimeter, they Ohm out at 200K.
I've had similar KS faults, blast the connections with contact cleaner and shove them on and off a few times, no new parts required
I've had similar KS faults, blast the connections with contact cleaner and shove them on and off a few times, no new parts required![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
LAjag
11-30-2018 05:46 AM
car5car
02-07-2016 12:51 PM
The Coupe
08-26-2011 10:24 PM
