P0357 code and intermittent "misfire"
Hello, I have a '99 Vanden Plas AJ27 N/A, Left hand drive.
I have a P0357 code that occurs intermittently (usually with the engine shaking/misfiring and 'restricted performance' displaying on the message center) and the workshop manual I have says that is
Ignition coil primary/secondary circuit malfunction, cyl 6
so that is the drivers side bank, second coil from the front bumper. Is that right?
I've replaced that coil from one I got off amazon. The car runs fine but, there the problem still happens occasionally, usually at first startup.
Where do I go from here?
The XK8 forum DIY sticky has a diagram and I have the link below. I'm not smart enough to just copy the diagram, so you'll have to scroll down.
XK8 & XKR 'HOW TO' / DIY Repair & Maintenance Links / Facts & Data - Jaguar Forums - Jaguar Enthusiasts Forum
PoorJagOwner (07-15-2017)
I just resolved similar issues with my car. Random misfires, different plugs misfiring, runs like crap. I spent a week chasing down error codes that would change all the time. Fixed a nagging vacuum leak, new knock sensor and o2 sensor, new coils. Still ran bad...then I put fresh gas in it. After a mile it ran like a champ. It was that last tank of fresh gas that caused all my problems but I did get all the other stuff done that needed doing.
