P0443 OBD-II Code and Check Engine Light
I had changed mine also, didnt fix it. same code. Then I checked the charcoal canisters. When you put gas in these things, (the car) do NOT top of the gas tank, you know, keep hitting the handle to get it as full as possible, the fuel has a tendency of getting into the vent tube hoses. I pulled my canisters and they were packed with gas smelled dust. Cleaned them and reinstalled and wala, no 443 code for 2 months now!
Before buying that valve if you try that. be sure to check the old one. Use a smoker or blow cigarette in one end and power it on with scanner or just jump power to it to see if it stops and starts with the smoke.
The part number for the 1999 XJ8 Carbon Canister was NNB6110AA and the updated revised part number is NNB6110AB.
Here are 2 JPEG files on the Evaporative Emission Control Single Canister System:
This first one shows all the components locations:
https://www.dropbox.com/s/2a4bqpdku4...%20Diagram.jpg
This next one compares the JTIS diagram to the JEPC (parts catalog) diagram.
https://www.dropbox.com/s/vhjx62qdb4...er%20Parts.jpg
Ebay photos of 1999 XJ8 used carbon canister (click on the image when the webpage opens):
https://www.dropbox.com/s/ydj2p7s2tt...20Canister.jpg
Jim Lombardi
Jim Lombardi
The following 2 users liked this post by jimlombardi:
mikebaker3 (03-06-2014),
times2fxp (03-06-2014)
mikebaker3 (03-09-2014)
BrentGardner
28
04-26-2024 03:08 AM
philwarner
12-06-2021 07:13 AM
