P1111 inlet air temp sensor, location
Hello
I have a pending code of p1111 and it says a fault in the inlet air temp sensor and I was wondering what this could be and where the sensor is located?
Is it in the Mass Air Sensor on the inlet after the air box? Going to try cleaning it and see what happens.
Thank you all
Thank you all
But I get a yellow warning on my meter saying it is not ready for smog test, no green check mark.
And when I look up that code it says IAT intermetant circuit. I looked at the IAT live reading and I see a steady reading then all of a sudden I see a series of spikes......looks just like an intermetant connection.
I have jiggled some wires with the engine running but have not been able to get it to spike.
When driving the spikes seem to come when I hit a bump. Sure looks like an intermettant circuit, but I cant find the sensor!!!!!!!!!!!!!!
Received 2,263 Likes
again it is a pending code. When I read the IAT data live I see spikes in the moving graph.
2003 XJ8.....which matches what the meter says.......intermittent circuit. Tried rapping on component parts in the area but can not duplicate the spikes.
Am assuming from the responses that it could be the MAF sensor which contains a temp sensor.
I have a ohm meter so can the resistance be measured across the sensor to see if good?
What reading is "good"?
What pins?
What pins?
If you clear a P1111 you are going to go on an extended 'vicious cycle'!!!!!!!!!!!!!!
Clear the P1111 and you will get P1000. Drive the car until you get P1111, Clear the P1111 and you will get P1000. Drive the car until you get P1111,Clear the P1111 and you will get P1000. Drive the car until you get P1111,Clear the P1111 and you will get P1000. Drive the car until you get P1111,Clear the P1111 and you will get P1000. Drive the car until you get P1111,Clear the P1111 and you will get P1000. Drive the car until you get P1111,Clear the P1111 and you will get P1000. Drive the car until you get P1111,Clear the P1111 and you will get P1000. Drive the car until you get P1111,Clear the P1111 and you will get P1000. Drive the car until you get P1111,Clear the P1111 and you will get P1000. Drive the car until you get P1111,Clear the P1111 and you will get P1000. Drive the car until you get P1111,Clear the P1111 and you will get P1000. Drive the car until you get P1111,Clear the P1111 and you will get P1000. Drive the car until you get P1111,Clear the P1111 and you will get P1000. Drive the car until you get P1111,Clear the P1111 and you will get P1000. Drive the car until you get P1111,Clear the P1111 and you will get P1000. Drive the car until you get P1111,
bob
bob
The following 2 users liked this post by motorcarman:
Jhartz (05-30-2016),
Moto Martin (07-30-2016)
silversurfer1221
27
09-27-2022 02:06 PM
