P1316, P1121, Restricted Performance, Failsafe Eng Mode. Throttle Body Time?
Old 04-19-2013 | 03:20 PM
JimmyL's Avatar
Talking Trouble, trouble, trouble
KorvetKeith, it sure sounds like the cam timing was the issue. PDRey55, it sounds like you need an OBDII code reader. They are not that expensive now days. Check around. I have an UltraGauge that displays all kinds of useful info while you are driving as well as displaying and resetting trouble codes. BTW, don't trust the temp gauge on these cars. They are notorious for telling you the engine has overheated after you're sitting on the side of the road with coolant spraying everywhere.
Old 04-21-2013 | 10:14 PM
korvetkeith's Avatar
P1121 persists and puts my car into engine failsafe mode, a lot. I replaced the pins (looks like it had been done before) for the TPS and the TB was rebuilt, as previously stated. Fork this car.
Old 04-22-2013 | 05:59 AM
Sean B's Avatar
what's wrong with slapping a recon TB on it, with a warranty? The P1121 is throttle pedal position sensor, TPPS, not TPS.
Old 04-22-2013 | 09:38 PM
I got the TB rebuilt by ASI already.
Where is the TPPS?
Old 04-22-2013 | 10:04 PM
sparkenzap's Avatar
Keith:
As you actually noticed early on in your postings, the AJ 27 throttle body has two sensors, one for the throttle pedal position and one for the throttle plate position. Since it it throttle by wire, the two are not necessarily the same.
Old 04-23-2013 | 08:29 AM
Originally Posted by sparkenzap
Keith:
Right, so I should be calling ASI? Does anyone know if they replace that when they rebuild the TB?
Old 07-05-2013 | 08:50 AM
A new to me throttle body from a salvage car solved this problem. So much for the ASI rebuild.
  #28
Old 07-05-2013 | 11:27 AM
flay's Avatar
Wow, seems like bad news as I want to have a rebuilt thru ASI as well. For the money they ask, both sensors should be changed! I want to have a rebuilt and to have the TB sent overseas , so a guarantee claim will cost a lot on shipping.
Old 07-05-2013 | 04:05 PM
jimlombardi's Avatar
Keith
ASI has a warantee on rebuilding Throttle Body. Have you called ASI and made them aware of the problems you have with the Throttle Body rebuild???
It is important that ASI makes good on any problems with the Throttle Body they rebuild.
A lot of us on this forum (including myself) have used ASI and had no issues with them.
I like to know if and how they responded (you probably have contacted them by now).
Jim Lombardi
The following 2 users liked this post by jimlombardi:
JimmyL (07-05-2013), Nicdilla (03-31-2014)
D.K
12-10-2023 03:05 AM
toronadomike
08-07-2022 04:41 PM
XJsc-guy
11-23-2015 02:56 PM
davidladewig
09-03-2015 07:32 PM
XFR_Gold
09-02-2015 01:24 PM
Quick Reply: P1316, P1121, Restricted Performance, Failsafe Eng Mode. Throttle Body Time?
