p1384
Received 1,815 Likes
Flip (06-13-2018)
Engine sounds normal at idle, no tapping or ticking! However, when applying the accelerator pedal, a slight ticking noise is heard. I also forgot to mention that I replaced all timing components and seals except the VVT carrier seals and checked continuity from both VVT solenoid connectors back to the ECM connector pins. My multi-meter beeps on all 4 wires, but I didn't have the resistance specs to verify if proper ohms were coming through. As of now I'm using 6 qts. of 5w-30 oil and 1 qt. of ATF. Any suggestions would help. Thanks!!!!
That ticking makes me think its a partially blocked oil port. Check this thread out, it doesn't say a lot more than I have, but its worth the read... https://www.jaguarforums.com/forum/x...ng-p1384-9146/
Here's another that works the connector angle... https://www.jaguarforums.com/forum/x...perated-68222/
Rocky125
01-08-2014 06:13 PM
