P1631 code, failsafe limp mode
Hello, first time post, long time lurker.
I have a 2003 XJR that keeps giving me a failsafe, limp mode and P1631 code. Usually happens after 40+ miles of driving, happens quicker and more frequently in warmer weather, almost immediately on hotter days.
Clearing codes with a handheld and waiting 30s-1 min allows you to drive again, sometimes for a few minutes, sometimes a few feet.
Worst instance it would crank, stumble
and stall. 90+ degree day, car in the sun. Had to remove the ecu and put in AC. Plugged back in and
made it 15-20 miles before it went out again.
Suspected a short in the ecu that flares up with heat but board looks perfect. Any ideas?
Its probably not going to be a direct answer, you'll have to research it some more. Try this (bookmark it also)... JagRepair.com - Jaguar Repair Information Resource ...you can do a search of the electrical diagram, download and review as you determine any faults. I wouldn't stop if you find a fault, be sure to trace it out for more or you'll be cussing yourself thinking you fixed the wrong thing when it could be multiple things.
