P1722 , but no tranny shops gonna get all my money!
Old 01-09-2011, 05:57 PM
Alvin Burns's Avatar
Which of your 3 Jags had the transmission problem? I'm wondering if I should expect a similar fault with my 02 XJ8L (78,000 miles). Thanks for sharing your knowledge and experience with those of us who have far less!
  #42
Old 01-20-2011, 03:38 PM
chinny4290's Avatar
I wish my transmission failed this way but my shop showed me, bits and pieces were everywhere.
Kinda like saying I'd rather have chlamydia versus herpes lol
  #43
Old 05-17-2011, 08:17 AM
Donzi's Avatar
Originally Posted by ukcat90
We be rolling again. Had a chance to put it all back together (no rush, it one of our 3 Jags)
but still not that time consuming if one was under a more timely situation.
The cost:
New A-drum-225.00
ZF manual-65.00
Trans pan gasket 25.00
Esso fluid 160.00
Couple o-rings- 6.00
Few cups o' Dunkin- 10.00
So for about 500.00-ish I got it done.... not 2,000 , or 3,0000, or 4,000 which any trans place would have been robbery. To this day I cannot understand why so many people buy used cars (especially Jags) then don't have the slightest clue about them. I just saw a recent post for someone asking where to add coolant, or why the mirror was not darkening? and don't gimme that "oh you were a newbie once and probibly asked these kind of questions... Gimme a break!
ukcat90
'90 xjs coupe
'00 xj8
'02 x-type
'72 mustang fastback
How many quarts of fluid did it take to refill it please?
  #44
Old 05-18-2011, 12:29 PM
viscoussquirrel's Avatar
Remember there's fluid in the lines and in the cooler and in the torque converter. The easiest way is to measure what you drain out.
  #45
Old 05-18-2011, 09:12 PM
Donzi's Avatar
oh, is there?
  #46
Old 05-19-2011, 02:53 AM
oh, is there?
Nope, it was a complete fabrication on my part.
  #47
Old 05-19-2011, 10:09 PM
Donzi's Avatar
Thanks for the INSIGHT...
  #48
Old 05-20-2011, 10:00 PM
ant17's Avatar
How can I tell what trans is in my car?
  #49
Old 05-21-2011, 02:51 AM
Sean B's Avatar
Received 1,357 Likes on 1,068 Posts
if it's normally aspirated its got a ZF box, lots of info on them here.
  #50
Old 05-21-2011, 08:28 AM
jimlombardi's Avatar
Received 1,621 Likes on 874 Posts
Default 1998 - 2003 XJ8 has ZF5HP24 transmission
Hi ant17
Your 2003 VDP (XJ8) has the ZF5HP24 transmission. The XJR has the Mercedes Benz W5A580 transmission.
ant17 (05-22-2011)
  #51
Old 06-26-2011, 02:43 PM
XJRJeff's Avatar
Default Found this reman drum in a search....
Here is the site I found. Have not had a chance to call them yet to see if they are still in business etc. Best price I have seen, 175 plus 100 for the core. Planning on replacing mine while I have the engine out putting in my new reman engine.
ZF5HP24 Forward Drum | (954) 781-3843
  #52
Old 06-27-2011, 12:39 PM
ixj8it's Avatar
Whoa, that is way cheaper than the $300 one I got from transparttech or whatever it was. I think I paid $285+$100 core, which I got back. When I was disassembling the a-drum, I noticed some of my o-rings on the piston inside were torn and I couldnt get a replacement. The guy from transparttech sold me a seal kit ~$200 and overnighted it to me. It was awesome
  #53
Old 06-28-2011, 04:38 PM
XJRJeff's Avatar
Default Seal Kit?
Hey ixj8it, do you happen to remember what the seal kit was? I was reading a link about a guy rebuilding the ZF5HP24 for a land rover application and he said a similar thing about the o-rings going between the a and b drums. I am of the opinion that while I am in there I should take care of all that I can within reason. I am just a bit unsure about taking apart more than I need to. Here is the land rover post link: http://www.rangerovers.net/forum/vie...hp?f=2&t=37767
  #54
Old 06-29-2011, 02:29 AM
jeiiomix's Avatar
Wow. cant believe this post is still so active after all this time. There is a company called Eriksson Industries in Connecticut (1-800-388-4418) and they are VERY familiar w/ the ZF5HP24... Theyre an authorized distributor... They know exactly what seals you need. I think I paid under 100 for all the O Rings and gaskets to repair the forward A drum. There are a few gaskets and a couple of O Rings. I have the exploded view of the unit if you want (which i got from eriksson) that I can email to you... It has the part numbers and such. I thought I was in over my head, but actually only took me about an hour to fix (not counting the time to get the tranny in and out). Let me know.
http://www.erikssonindustries.com/
  #55
Old 06-30-2011, 09:49 PM
ixj8it's Avatar
The seal kit I bought was high if the eriksson one is only $100, not to mention the kit I got was for an Audi AWD transmission I believe. All I used from it was the pan gasket and the piston o-rings.
  #56
Old 07-11-2011, 11:28 PM
supergordo's Avatar
Originally Posted by viscoussquirrel
Has anyone done a writeup yet on pulling the trans?
I know this post is 6 months old, but if you or anyone needs some insight on pulling and installing this tranny in the XJ8 to send me a message. I am a mechanic and I just did a swap for a buddy of mine. The job can be annoying at times but I've had other cars be much worse.
The toughest part is the left side of the exhaust.
  #57
Old 07-12-2011, 12:05 PM
Default XJR Transmission Removal & Install extract from JTIS21
Hi
I move this post reply to its own new thread.
Jim Lombardi
  #58
Old 11-22-2011, 08:29 AM
ross1's Avatar
Default PAGING ukcat90
Thread revival; Has anyone contact info for member ukcat90?
He's somewhat local and I could sure use that ZF manual.
  #59
Old 11-22-2011, 08:19 PM
Hi
I posted the ZF factory Repair manual PDF file 5/20 this year. Here is the weblink to the forum thread:
https://www.jaguarforums.com/forum/x...hed-faq-54929/
Thread also includes the spare parts manual.
Jim Lombardi
  #60
Old 11-23-2011, 04:48 AM
ross1's Avatar
Thank you ,sir!
Quick Reply: P1722 , but no tranny shops gonna get all my money!
