P300 P303 P304 P1313 P405 cured
Just an FYI.....
The car (20K only)was misfiring badly, after being stored in the garage for 2 months, under load and running rough at idle. I checked all the usual stuff, fuel filter, fuel pressure, various voltages, vacuum leaks etc. to no avail.
Finally decided to pull plugs, although with the mileage I was sure there would be no issues.
Pulled left-hand side first, all looked good. Pulled right-hand side and coils and plugs were, to my surprise, rusty. I cleaned everything and made sure no water was present and put it all back together to find it still ran terribly.
So I took it apart again and after looking carefully at the plugs I found two with hairline cracks. Fitted new plugs and bingo, runs like a dream.
I think water must have gotten in at the carwash and I put it into storage immediately after. I think the cracks were probably caused by water splashing on the hot plugs.
Anyway, for what it is worth, that is my story. Hopefully it will help someone else.
The following 2 users liked this post by phemes:
ericjansen (09-16-2016),
Highhorse (09-16-2016)
