Paint advice please
Not really.
New paint will look different from older paint depending on how old it is.
The other issue is the clear coat. Getting a patch of clear coat to "feather in" with original clear coat is extremely difficult to do properly.
Getting that complete panel done would be the best bet I think and even tho a slightly different "shade" to the rest would not be too bad.
I think a good paint shop would want to repaint and coat the panel and trunk lid, and also feather into the tops of the rear fenders to do it right. And it wouldn't be cheap. I'm guessing $650-$1,000
Cheaper shops could make it look better than it is now for less, but you get what you pay for.
Paint work is almost all labour, although the paint they use today is very expensive too ! I recently had the hood repainted on my previous car, a 2007 X358, due to stones damage. It cost around £400. If the base coat is undamaged albeit faded, then it is just a case of removing the clearcoat, applying base coat, then replacing the topcoat. There may be a slight variance in the shade of the new and old. It all depends on how much of a perfectionist you are. If you want it perfect, then you'd be looking at refinishing the trunk lid and the tops of each rear wing.
jagosaurus
09-25-2012 06:50 AM
