Paint on the chrome exhaust tip
people who fixed a dent and did some paint spray on the left rear area of my XJR managed to not tape off a part of the exhaust tip. There is some platinum silver paint on the exhaust tip. This is not a major issue and I do not notice it often, but when I do it is annoying. Can anyone recommend a way to reasonably remove this paint without damaging the stainless steel exhaust tip?
thank you
thank you
Received 9,010 Likes
![Name: car01.jpg
Size: 19.3 KB](https://www.jaguarforums.com/forum/attachments/xj-xj8-xjr-x308-27/175680d1501294586-paint-chrome-exhaust-tip-car01.jpg)
Paint thinners should do the trick I guess......failing that check out the detailing section for other results.
Depending on how nice n shiny your tips are or how shiny you want them to be, you can try very fine steel wool, followed by wet n dry 1500 and Autosol polish or similar to finish for a clean high gloss shine!
So perhaps this will frustrate the pureist -
My Uncle 40 years ago showed me that SS/chrome could easily be cleaned with #0000 steel wool and WD40.
This has worked wonders for me. The #0000 wool is key, as it is fine enough not to scratch or leave any kind of burnish.
I have taken a many sorry looking piece of brightwork and turned it new with this approach.
In fact I did my exhaust tips this way.
Dan R (11-20-2010)
I use Nitric Acid and Scotch Bright pads at work for cleaning and restoring the finish on my pool gutters. It will bring it back to new finish no matter what the stain is. The pad is a little less invasive then even 0000 steel wool (which I use to keey the crappy Jap chrome on my CB clean and rust free since I ride it in sleet, snow and salt). If all else fails I'd suggest the Nitric but it isn't cheap and isn't real healthy. Nothing that comes in glass with a skull and crossbones on the label is though I guess.
![Icon Wink](https://www.jaguarforums.com/forum/images/smilies/icon_wink.gif)
Dan R (11-20-2010)
FS[SouthWest]: Red 2001 XK8 Convertible in Colorado
picard
10-12-2015 11:56 AM
1964Daimler
09-09-2015 11:28 AM
