Parking Brake Replacement
I'm assuming you mean the brake shoes. Pretty straight forward. Use a screwdriver to turn the toothed wheel to pull the shoes in a bit. Unhook the springs and the pins holding in the shoes. Pins are usually 90 degree turn or similar.
Install is reverse, then adjust.
That said, the chances you have worn out your parking brake shoes has got to be essentially zero, so I'm wondering why you want to change them
Thank you for sharing, that helped to visualize the steps more.
i wanted to change them because when i engage the parking brake (emergency brake) the car still moves a bit (much more noticeable on inclines) so i figured time to change them out? Would you just recommend tightening the adjusters?
X308TheKingCharles (12-06-2023)
The following 2 users liked this post by Addicted2boost:
Jhartz (12-08-2023),
You might want to follow the factory procedure for setting the parking brakes, it addresses both adjustments:
- ensure parking brake cable is slack (not engaged)
- Adjust drum pad adjuster in one wheel just until the wheel can't be turned by hand anymore. Back off by 4 ish notches on the adjuster.
- Repeat above on other side wheel.
- Finally, adjust 13mm nut on parking brake cable linkage so that you get the desired 4 clicks of pbrake lever to engagement.
The following 2 users liked this post by nilanium:
Hooli (12-11-2023),
