Parking lights, both front and rear, not working
I had to leave my car for a couple of weeks, and when I got back the battery was drained. After charging it, all seems to work normally, except that there's a warning on the display that a rear lamp is not working. None of the four parking/position lights (both front and rear) are working.
I've checked the lamps, relay 3, and fuses 19 and 21 in the rear fuse box. The number plate lamps, brake lights and headlights all work. I even unplugged the battery for a few minutes, and there's no difference.
I suspect that there are some other fuses and relays connected to this, but the manual only state these ones. I also think that the error is close to the lamps, as the computer knows that the lamps aren't working.
BrentGardner
28
04-26-2024 03:08 AM
Doberman_Fan
22
12-24-2019 06:21 AM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
