Parrot 9200 install
Hello all,
I'm attempting to install a parrot mk9200 into my 2001 xjr. I have an amplified Alpine system and at this point all I want to do is get the bluetooth working with the car's audio. I tried using the connector under the center console and that got me power to the parrot but nothing else. I'm guessing it would work if I didn't have the amplifier.
I've read the posts but must be thick headed. Has anyone actually done this or know how to?
Thanks in advance
Thanks in advance
You might try looking here for a connector for the phone plug in the console. Most of the instructions are for the Motorola kits, T605, but I know that SARC has installed a different parrot model in his XJR. The main thing you need is the wiring diagram which I belive is in the JTIS and some of the posts I believe by Quadmaniac and SARC.
Don't give up, this is doable. I did it with the T605 as it is very cheap and was well documented. It works extremely well, I really couldn't ask for more.
raschwar (03-10-2011)
Hi
I found and posted where to download a free Jaguar Electrical guide.
Here is the Link to my posting in "1998 XJ8 lighting problem":
https://www.jaguarforums.com/forum/s...690#post316690
You will note that it is the same electrical guide that is in the JTIS.
Jim Lombardi
Jim Lombardi
I installed a Parrot 9100 in my 99 XJ8. That system also has a built in amp but it still had Line Level Out for rh and lh channels.
I believe there are two ways to go "in" to your radio. First is using the CD input method and the other is using the Phone input method. I chose CD because I wanted to be able to run my iPod in stereo. If you choose to do a stereo install it's a bit tougher because you need to tap into the wires at the CD changer or do like I did and get at them behind the radio.
If you only want to use the phone then you could use the plug under the console but then you only get a mono input to the radio.
The link to the electrical schematic that Jim posted above is the one I used for my job and it made things a whole lot easier.
Ken
Ken
philwarner
43
09-10-2023 11:30 AM
aholbro1
08-05-2021 05:02 AM
