Part load Breather after cleaning problem
Removed the PLB socket and cleaned the nipple using 3/32 drill . Had a problem getting connection back on. {any one know an easy way to do this}
Well now I have a noisy and poorly running engine and a hiss {air / vacuum .escaping ]
What have I done ? I may have pulled on the PLB tubing a bit too much .
Ah yes the tube disappears under the SC.
Any ideas of fix ?
One good note was in removing the connector I sprayed WD-40 on it , let engine warm up and slid a thin 9?16" open end wrench around nipple between it and the connector. Gently pried / pushed up rotating wrench . Connector slid right off . No pulling or tugging except DAH! on re connect.
Any ideas
Txs
Any ideas of fix ?
Any ideas
Txs
![Icon Werd](https://www.jaguarforums.com/forum/images/smilies/icon_werd.gif)
BrentGardner
28
04-26-2024 03:08 AM
SingBlueSilver
08-27-2015 02:20 PM
