Passenger Rear Door Won't Lock...
Hi ho Ben7,
If you want to check-out and or replace your door actuator, here is a link to a video tutorial. Robert's video was very helpful in replacing my actuator.
https://www.jaguarforums.com/forum/x...-video-110408/
fredd60 (03-11-2015)
I found this site, just by googleing. Not recommending using them.
Jaguar Door Lock Actuator | XJ6 Vanden Plas - 1993 1994 1990 1989
Google for your part yourself, there are other places to buy from.
Rear door lock problem
Hi, I had the same problem on my X308. S/H modules not expensive, bought an actuator on ebay for just £12. Before pulling everything out, (not as easy as the front doors), I squirted WD40 all over the mechanism and worked the door button up and down several times. Voila.... everything working perfectly both manually and central locking. Might not be your remedy but certainly worth a try.
99xk8guy
06-05-2023 06:28 AM
