Passenger side rear brake light not working, already replaced bulb
#61
I am having the same problem everyone else is. I have access to a parts car that has not been picked over. Assuming that the SLCM..SCLM ...or whatever, is still on the parts car.....2001 jag xj8 just like mine would it be likely that I could get it from the parts car and replace mine with it and fix the problem......specifically is this a part, unlike a muffler...that can be put on used....
As you can tell....auto repair is not my bag...I just want to get this taken care of without spending a grand for a brake light.
#62
Old thread but I was searching for just this issue and wanted to post my solution. My SLCM output for the right brake light is bad. I may eventually repair it but in the meantime I simply sliced my orange w/yellow trace wire going to the right side brake light bulb to the orange wire at the trailer connector. The trailer connector is in the trunk fuse box and the brake light wiring runs right past the fuse box. The orange wire in the trailer connector is directly from the third brake light relay. I cut loose the wire going back to the SLCM just because I did not want to back feed it in case it might have unintended results. I expected to still have a lamp failure message but that even went away. Someone correct me if I am wrong but I believe all I lost was the lamp monitoring on the right stop lamp by doing this. Maybe I won't even bother to repair the SLCM
#64
I've read through this thread with great interest as my RH Brakelight was also not working. Before I saw this thread I picked up from another site that it was something to do with the Security Module so I proceeded to do my own work around which involved looping from the LH working brakelight, in addition I wired another temporary lamp from the feed from the security module and down to the car chassis to disable the "check rear lights" message, it has worked for about 2 months until I discovered this thread. Due to the warning from Jackshaheen about overheating etc. I have disconnected the loop between the brakelights and wired from the center brakelight to the faulty RH brake light and everything seems to be working. I hope that the center breaklight does not use a security module but one thing I noticed was that the wiring to the center breaklight is about 4 times the gauge of the brake breaklights.
As I live in Tenerife I cannot get my Security module fixed as it would mean sending the unit to the UK and losing the use of my car for quite a while. Unfortunately I am unable to solder a printed circuit board due to an illness which causes my hands to shake too much.
Regards,
Dave
Regards,
Dave
#65
#66
Hi Plums
I've spread the word but still awaiting a response. I don't want to just call on spec because if the damage the unit then I'm stuck. I'm hoping that someone will be able to post an image of the BTS409L1 chip as I've managed to source a supply but when I asked the question if it was used in a jaguar control unit they said possibly but could I supply them with an image of the chip just to be certain. Hope someone on the forum has such an image just to save me stripping down my own unit in case I cause any further damage.
Regards,
Dave
Regards,
Dave
#67
Hi Plums
Regards,
Dave
Regards,
Dave
You want the one in the SMD package style.
Hope that helps you
Jack
#68
#71
#72
If any of you guys have this problem and you are sure its your module AND you don't feel comfortable soldering a new chip on the board then if you will pay shipping both ways and for the part(s) I will fix it for nothing or maybe a small fee (more likely nothing - kinda fun to do since all we do now as techs is module swap).
Cheers![Smile](https://www.jaguarforums.com/forum/images/smilies/smile.gif)
will you still do this? Please send me your email and address and I will send it to you with a check.
Lionel
#73
#74
#75
Hey Jack, I have the same problem. Can I send my module to you? I tried to find where to pm you but I don't see it. Also, how long does it take? My Jag is my only transportation so maybe i'd have to take the cab to work or something until it's finished. Thnx in advance!
I no longer have my XJ8 but do have some parts to repair these modules.
If this is not an XJ8 then I would not be willing to fix your module.
The modules may be different. I have no idea what they put in every model Jag they made.
They also may be the same. I would have to take a look at your module.
#76
If you have an XJ8 around the 2001 year then yes I can fix it.
Is your problem one brake light always on or always off? Need more info...
#77
Forgot to answer you question. It will all depend on how you ship it to me and what you want to pay for return shipping. I can repair the module in one day. So ship it to me, I get it on say Monday. I fix it Monday and ship it back to you Monday
#78
Yea, my passenger side brake light is off and not working at all. I put a new bulb in it and nothing. I also used the bulb from the left side and nothing happened. So I decided it might be a fuse or something until I saw this forum. However, mine is an S-Type and not the XJ. If you find out more info about the module in my version, plz let me know!
Not sure about the module the S type had in it but it could be the same or similarly designed module. Where is your module mounted? In the trunk? Can you get a number off of it?
And MAYBE take it apart to take a picture of the circuit board.
#79
