Passenger side rear brake light not working, already replaced bulb
Old 03-25-2015, 04:46 PM
scottatl's Avatar
Good news, I cleaned the board and connections with some de-ox and the problem seems solved
  #102
Old 05-03-2015, 02:51 AM
Sphull's Avatar
Default Break lights not working
I have checked everything including:break light switch, lamps, fuses, relays, control box but all three break lights will not work. Seems like no 12 v feed to the harness connected to the break light switch. I think there might be some wiring issues. Can anyone please advise.
  #103
Old 08-02-2015, 01:21 PM
Jerry151's Avatar
Unhappy Help me please!!!
HI All,
I need help.
My transistor Q11 is drop out and I want to know what is written on it.
Regards
Jerry
Attached Thumbnails  Passenger side rear brake light not working, already replaced bulb-70173d1390586688-passenger-side-rear-brake-light-not-working-already-replaced-bulb-slcm-photo-ci.jpg
  #104
Old 09-08-2016, 04:37 PM
lzarc1's Avatar
Default SLCM replacement
SLCM replacement with exactly the same part numbers and VCATS; I was told it should/would work, however that didn't work does anyone know about reprogramming or any other solution or cause?
  #105
Old 09-10-2016, 10:45 AM
lzarc1's Avatar
Hi, I have the same problem discussed in SLCM posts; I checked for wiring problems and did not visually see any bad wires, I of course checked fuses and relays, so I proceeded to the SLCM which was fried; by the way my car is a 2002 XJ8 Vnp; So I found one on Ebay with the same VCATS and 008 security code but I still do not have right brake light, however one side of the dual filament on the right side does light up, and I also do not have tail lights. do you have any idea? Or is their any additional programing needed; my key pad does work when I did the light switch program. I would appreciate any suggestions.
Last edited by lzarc1; 09-10-2016 at 10:52 AM. Reason: remove name to make more general
  #106
Old 03-24-2017, 08:44 AM
johnro6659's Avatar
I recently posted a new thread on this issue because my passenger side brake light doesn't work thought it was a bulb etc. After reading all the posts fixes and other problems and as much as I love my Jag and the ones I have owned before this one I have one question what were they smoking when they designed this system? I can understand the flashes being wired into the security system but can't figure out the reasoning to run the brake lights thru the security SLCM. Since the first day I got my first day everyone said you do not want a Jag they have the worse electrical systems ever! I have had three and this is the first one that had any issues aside from regular maintenance. I'll be searching other threads for other suggestions but I will be popping the SLCM out and cleaning contacts checking for bad solder joints and wires. So far I haven't been able to do much seeing this car is my daily driver and I leave the house early and come home late! I would like to thank everyone for their input here, on my thread and the others I have been pulling up and bookmarking. I hope some time in the near future the forum can make a single thread with the best repair ideas it would make it a bit easier.
  #107
Old 04-21-2018, 05:52 PM
jagman40207's Avatar
Default I Replaced the Driver Chip Myself
Today is 4/21/18. I had the "Check Rear Lights" error and no passenger-side brake light on my 2003 X308.
I bought a pack of three of the Infineon/Siemens high-side driver chips (SMD mount) from Mouser Electronics (one for use with the passenger-side brake light and two for spares). They were only $2.91 each (plus shipping). Mouser still has thousands.
Removing the SLCM board was straight-forward and easy; just refer to Jim Lombardi's photos, pull an outdoor chair up to you bumper to sit and relax during the process. A few simple hand tools are all you need.
Removing the driver chip from the SLCM board was just as straight-forward: heat each leg of the chip with the tip of the soldering iron and lift the four legs one at a time (using a sharp, curved soldering tool), then heat the tab for a couple of seconds while pulling with needle-nose pliers (wear eye protection). Use a clean, well-tinned soldering tip, especially for the tab.
Soldering the new chip back in is just as easy: make sure the circuit board pads have a little solder tinned onto them (not too much) with a little rosin on top (including the tab pad). Ensure the new chip is exactly centered on the pads then tack and wick each leg. Add a little more tinning to your soldering tip for heating and pushing down on the tab while applying pressure to the chip body with some other push-down tool. Clean the area with electronics cleaner.
There, you're done. Re-assembly is the reverse of removal. Pat yourself on the back for saving the cost of a $950 circuit board plus the $300+ dollars to have a new board re-programmed and installed.
The following 4 users liked this post by jagman40207:
Jhartz (04-22-2018), johnro6659 (04-22-2018), motorcarman (04-21-2018), Salomon5230 (09-12-2021)
  #108
Old 01-21-2020, 03:37 AM
Jaggster's Avatar
Default S-type RH brake light
I had broken bulb and blown 10 A fuse. This blown fuse caused tail light on the RH side to be dimmer than LH. S-type has 2 brake bulbs/side. Fuse only affects the outer one, seems to be dead. Brake bulb fail text on the dash.
  #109
Old 02-08-2020, 12:59 PM
DoodleDandy1's Avatar
.hey Jack looks like I may be in need of your skill set.there was a time.I had great eyesight and could manage a task like this but now at 72 I am just about blind in one eye and could barely see out the other. I was able to remove the SCLM out of my 96 x300 with apparently the same issue. If you are free and willing to tackle my situation, There is $50 in it for your labor in addition to the cost for the parts.. Just respond with details on where to send my part and cost of components as best as you can estimate and I am ready to ship to you..
Thank you Jack for your great posting.
Andy F.
  #110
Old 09-12-2021, 05:03 PM
Salomon5230's Avatar
Hi Jagman,
Writing from Denmark.
I have the exact same symptom on my 2002 X308, ie. "check rear light" and no function of the right (passenger) side brake light. Have found that the voltage to the bulb, is 4V instead of 12V when I press the brake pedal. Exposed the SLCM and found on the out-put to the brake light (pin #3) low voltage (4V) also. Harnes (BT) intact. So, I think I will need to change "high-side driver chip" as described by you.
It would be very helpful, if you could you tell me:
1) where the chip is located on the circuit board?
2) the mouser part number on the chip?
Kind regards
Søren
Last edited by GGG; 09-13-2021 at 02:56 AM. Reason: Automatically locked for moderation - unlocked
  #111
Old 03-24-2023, 01:28 PM
Wyldman's Avatar
Default Jag fix
Originally Posted by jackshaheen
Dave, that is the correct part number however they can come in three different package styles (standard, straight leads and SMD).
You want the one in the SMD package style.
Hope that helps you
Jack
Jack are you still repairing these security modules ?
  #112
Old 09-12-2023, 04:30 PM
Tbolt's Avatar
If any of you guys have this problem and you are sure its your module AND you don't feel comfortable soldering a new chip on the board then if you will pay shipping both ways and for the part(s) I will fix it for nothing or maybe a small fee (more likely nothing - kinda fun to do since all we do now as techs is module swap).
are you still fixing the modules?
  #113
Old 09-13-2023, 05:56 AM
jackshaheen's Avatar
Hello. Yes and no. I can fix your module however I would have to get the parts and I have no way to test your module since my Jag was given to my son and he sold it after owning it for many years. He needed the garage space.
So the short answer is yes I can fix it however would have to get the parts needed.
Jack
  #114
Old 09-13-2023, 01:33 PM
Tbolt's Avatar
Jack
I’d to get it repaired.What do we do next?
  #115
Old 09-14-2023, 10:44 AM
A few questions I need to ask you first.
1. What is the year and model of your Jag?
2. Can your remove the module yourself?
3. What is wrong with your module? Some rear lights (like brake lights) not working?
  #116
Old 09-14-2023, 02:52 PM
Tbolt's Avatar
2000 xj8.I believe I can remove it.The left rear brake(driver side) light is not working.
Earnest
12-28-2021 09:37 AM
Jersey City Jaguar
09-12-2018 04:16 PM
Burnham
08-27-2016 03:29 AM
inertian
06-17-2011 06:59 AM
Nerius
04-21-2010 11:43 AM
Quick Reply: Passenger side rear brake light not working, already replaced bulb
