Passenger window going down on its own
Hi all,
I have this problem where the passenger window just goes down on its own without me doing anything. When it first started to happen, I was able to use the passengers own window rocker switch to close the window. It would happen randomly whilst driving.
More recently, the problem seems to have got worst, the window almost alway goes fully down when I start the car ( and more frequently when driving). The only way now that it goes up, is by holding up BOTH the rocker switches on the passenger side AND driver side master control (for the passenger window).
Any ideas if something just needs to be reset or if the actual switch is faulty, or even a connection issue?
Thanks.
Thanks.
You could try the battery reset, and see if that helps. Otherwise, try disconnecting the window switches themselves. Start with just the switch on that door, see if still does it. Then try the driver's switch by itself. Then both. Sucks to have to pull apart to check it (not that it's THAT hard but still).. that might narrow it down.
Then you can do all the other stuff.
I had the battery reset soon after I posted. Disconnected the terminals,left for about 5 mins but same thing.
I also decide to remove the door trim panel. Disconnected the rocker switch connector, reconnecting it, I can hear a single click, but the switch wasn't doing anything. For whatever reason, when I removed the panel, and started the car, the window didn't go down on its own. I think this just may have been coincidence perhaps.
Would a problem with the battery prevent the switch working at all though? All the other window switches work fine. It's a relative new, Bosch battery. Replaced about 2-3 years ago.
Should have said, I'm in the UK. I don't believe we get such free test.
WTB[Australia]: XJC parts required
andytork
09-22-2015 07:01 AM
