PDU User Guide Rear fog lamps
I have a trouble with my rear fog lamps. Although the switch works properly and bulbs are O.K. there isn't no light
. So I decided to look at the workshop manual. However it isn't helpful
with electrical matters and it refers to PDU User Guide. Do you what is this guide? Where I can find it?
By the way, I would like to notice that although all the directions indicator work properly, the dashboard acts very fast (as some bulb is failed). I don't know if this has any conection with the rear fog lights.
Thanks for your greta help!
![Frown](https://www.jaguarforums.com/forum/images/smilies/frown.gif)
Jaguar PDU (portable diagnostic unit) replaced JDS (jaguar diagnostic system).
PDU was superseded by WDS but WDS will not read the cars from 1988 to 1995.
You should just get a proper Electrical Guide for the correct MY.
You should also include MAKE, MODEL, YEAR to get accurate info.
bob gauff
bob gauff
adriaxj8 (11-19-2012)
Thank you for your reply.
I have a Jaguar XJ8 3.2 from 1999. I think that previous owner has done bad things on the electrical system: Symptoms are:
- Rear fog lights don't work although bulbs and swicht are O.K
- Boot lamps only work if engine is on (I checked the wires and are fine)
- Altough Reverse parking aid is fitted (have sensors and module) it doesn't work. Moreover I don't have the wire that conects in the module
The only clue that I have is some wires in the trunk join by tape. Please, see the picture (close to the battery).
How can I check where the failure comes from?
Thank you
Thank you
I have done some pictures of the cut wires:
Please, does somebody know what are they for?
They are my clue to my electrical problems:
- Rear fog lights not working
- No conector for the rear park aid module
- Boot lamps only work if car is on
Thank you!
I wish you a Merry Christmas and a Happy New Year!
Thank you!
rsa760041
23
09-25-2015 01:33 PM
FS[SouthEast]: Rain X waterproof car cover NEW
Sublyminal
09-03-2015 04:48 PM
