Recently I had 2 trips with my car suddenly going into Fail Safe mode. Not Fun. Fault code shows as P-1121 which the manual lists as: “Pedal position sensor has announced its retirement”
I know the Pedal position sensor is unavailable but I googled the Denso # on the sensor and a partial match comes up for a Toyota/Lexus “Throttle Boby level sensor”. Clearly not the same part but the potentiometer portion looks identical.
The part is only $58.00 on Amazon so if it could be adapted to rebuild the PPS it would be a great option to having the throttle body rebuilt (screen shot below).
-The inner cam (that connects to the throttle plate) is different – the Jag cam would need to be swapped
-The outer cam is also different. It looks like a mirror image so the potentiometer must rotate the opposite direction on the Toyota unit. Again, the cam would need to be switched out.
-Something that gives me caution is that the orientation of the shaft relative to the connector is different between our sensor and the Toyota sensor. I assume that the shaft could be rotated to match the Jag unit and then change out the front and back cams. But that is the big if.
- I think the potentiometer is the same. The only part numbers are on the cable cam for each unit. If Denso made different potentiometers, then there would likely be a part number on it.
Over the years there has been a lot of discussion about this part. It would appear that Jaguar went to a lot of trouble to make sure that it couldn't be replaced, thus rendering the car useless. I assume they tied Denso into a legally binding agreement not to make anything similar. Fixing the problem required a complete new throttle body, at about $2,000 , but they may not be available now. The only other solution is to buy a throttle position sensor for a racing engine. They can be specified with the parameters you require. Cost is about $200.
Throttle body and throttle pedal from Robert rawle in South Wales UK Britain I had the same problem I replaced the complete throttle pedal from jaguar with the sensors I payed £55 for it and I found a throttle body sensor complete body on ebay for about £60 I had them checked and put in problem solved check tour maf sencor that went with me tryed ones on ebay new did not work I bought a densco original from jaguar that was about £70 to £80 put original on if you look on Google type in British jaguar specialists you will find different ones who will help and send around the world a good one is David manners UK I got a 2005 xjr hope this will help from Robert rawle
