Pillar pod in XJR
pat
Autoparts stores sell the brand VHT which makes automotive paints and interior colors. The can will indicate if it is for interior plastics. You may have a difficult time finding the interior color to match a Jag, but the big three US manufacturers are well represented.
The other way is to find an Auto paint retailer who has access to look up your VIN and interior paint codes. He will then be able to mix what you want and should be able to package it into an aerosol can for your use.
If you're in Delaware give Finishmaster in Wilmington a call at 302) 658-4070. They will be able to at least match your interior color with a chip and sell you the correct paint. Remember there are about 10 different interior colors in any one car so get the chip ring and go out to your car and match the pillar post with the color chip closest to your pillar color. Make sure to clean the plastic and use adhesive promoter on the plastic. Also, only use three coats of paint, any more than that and it will not adhere as well, don't ask.
BTW, I have done this twice with my truck and it worked out great. I live in Northern California though and my paint supplier has the ability to mix what I want anytime...
WTB[SouthEast]: 2000 XJR door seal
moff1959
09-26-2015 05:35 PM
BlacXJRcat
09-25-2015 06:43 PM
