pinking and clunking
Guest
Posts: n/a
i was sure that there would be posts part naswering these questions already, but i still appreciate specific help
xj8, 2002, vdp, 100K miles
1. minor pinking when its pushed hard up hill. i think this has only just started, but not sure as i rarely push it, but now i know there might be a problem i cant stop testing it! not sure if i can remedy by buying a higher octane fuel? or get a new knock sensor - if the latter then is it a easy job for my home garage - i am pretty incompetent mechanically
2. clunking on front suspension. odd thing is it isnt that bad on rough ground, but a minor bump or two on a flatish road and it clunks. not that loud, but i worry there is trouble in store.
Hi and welcome to the forum
Here is the weblink to Low octane gas pinging forum tread:
https://www.jaguarforums.com/forum/x...-change-44130/
It should answer all of your questions about the pinging issue you are having with your XJ8.
Jim Lombardi
Jim Lombardi
Hello again
Here another forum thread - this time on Front End Clunking:
https://www.jaguarforums.com/forum/x...visited-47809/
It gives several tips on what can be causing your clunking issue.
Jim Lombardi
Jim Lombardi
Chuck Schexnayder
33
10-24-2015 10:20 PM
philwarner
09-16-2015 10:40 PM
