Plastic coolant system parts are driving me nuts
Tonight the plastic coolant overflow tank decided to burst into three pieces. I am wondering what might have been plugged or restricted that might have caused the tank to over pressurize. Or it might have been the fact is plastic and degraded.
Any thoughts? I am going to replace it tomorrow, if I can find one local.
I have had one fail and have a leak now. I have a concern about not only the plastic overflow tank but all the other plastic parts on and in the engine. Everyone believes that the XK8/R is a classic that will endure forever but what shape do you think the plastic will be in when the cars are 50 years old like the E types?
Excess pressure is released by the cap on the reservoir. Heard of it failing by not holding pressure but not from too much pressure.
If your cap is leaking on the top of the thermostat housing, check the threads on the housing. My housing was cracked and I could not get that cap to seal. I thought it was the cap and went through about three until I spotted the crack in the housing. When I was taking it apart it started crumbling. So I replaced everything plastic... except the tank. What a mess.
I am wondering how many jag radiators are filled with the mushy plastic debris from those parts.
THe issue is that this is not an 'overflow' tank, as it is at full cooling system pressure.
The typical overflow or 'coolant recovery system' uses an overflow tank that is not pressurized. The radiator cap has a pressure relief valve that, when overpressured, allows coolant to flow to the tank. The cap also has a vacuum valve that allows coolant to be pulled back through the cap when the system cools down and the coolant shrinks.
The Jag (and some other modern cars) uses a tank that is at full system pressure, and as such, can burst when the plastic weakens through age. I'm not sure what the advantage of this would be except, perhaps, reducing coolant oxidation due to contact with air in an unpressurized overflow tank.
The issue certainly shows up as more catastrophic when the integrity of the sealed cooling system is lost due to plastic failure.
Apparently, plastic cooling parts fail on some cars and not on others. On the other, less technical forum, someone made the conjecture and offered links to an anti-freeze site that discussed anti corrosion additives in anti-freeze. The site claimed that different plastic compounds were attacked by some of the "standard" anti-freeze compounds. I am wondering if anyone who has used Jaguar brand anti-freeze exclusively has experienced the plastic failure?
Excellent point about the antifreeze formula. I've preached endlessly about the importantance of using the correct, factory specced coolant formula for the given MY. In late model Jaguars (1999, mid-year on), an OAT formula is specified. Jaguar designs all of the cooling components, including plastic compounds to be compatible with the specified formula. So, when owners choose different formula types, e.g - HOAT, NOAT, traditional green, phosphate, non-phosphate, etc., they are playing with chemistry that might have longterm ill-effects with little understanding of the real cause for failures or the nexus to the coolant formula.
The other issue - cracked bleeder cap on the thermostat tower is ALWAYS caused by overtightening this cap. Here is a tip for sealing this plastic cap with a guarantee it will not leak....or crack. Wrap the threads three or four times with plumbing teflon tape, wrapped in a CLOCKWISE direction when looking down at the tower. Replace the cap and HAND- TIGHTEN, If there is any seepage of coolant after the engine has warmed up and cooled back down tighten about 1/16th of a turn more with an allen wrench. This tower cap will NEVER leak and should never crack thereafter. It has to be a new cap however, if the old one is already stress cracked from overtightening.
kvmentor (03-05-2011)
BrentGardner
28
04-26-2024 03:08 AM
innzane
08-27-2015 07:58 PM
