Poor Air Conditioning Performance?
The HVAC system in my 03 XJ8 does not appear to be operating correctly. The air is not very cold. Today the center vent temperature read 78 degrees in Auto A/C mode…which was about the same as the exterior temperature. I have only had the car for a few weeks so I can not comment on how it worked in the past.
Does the x308 have any common HVAC troublesome areas I should check first?
Thanks,
Joe
Thanks,
Joe
Thanks for the reply.
I quickly looked under the hood this evening and the compressor clutch appears to be engaging as it does spin, but I do not hear the usual click of the clutch engaging properly. Also, the low side lines leading from the receiver/drier are not cold to the touch as they are on all of my other cars with functioning A/C. If I had to guess I would say it is the compressor clutch or compressor itself.
I reviewed the warranty paper work from the Jaguar dealer and this appears to be covered under the 60 day 2k warranty. I sent an email to the dealer to get more info.
Thanks again,
Thanks again,
Wolfy
05-28-2024 08:06 AM
aholbro1
08-05-2021 05:02 AM
scottatl
09-04-2015 08:08 PM
