Power Brake not working
The hydraulic pump is not getting electricity. We've replaced the relay and confirmed that juice is going to the relay, but the electricity doesn't make it to the hydraulic pump or the abs braking system. besides extensive electrical troubleshooting, does anyone have any other ideas or similar problems that have been fixed?
Your description of your particular problem is pretty unclear, but as an answer to what seems to be your specific question,YES, there are known issues with the electical solder joint on the motor leads on the ABS module. Se archives. Other known issues are connectors at wheel sensors. A better description of what synptoms you have will probably get some pretty good response.
sterling (01-11-2011)
BrentGardner
28
04-26-2024 03:08 AM
Robert1968
06-24-2017 11:16 AM
FS[SouthEast]: GenRad GDS-510 scan tool
johnnie ryall
10-19-2015 09:44 PM
Fraser Mitchell
10-01-2015 04:06 AM
