Power drain...
Just got my car back from the ***********...they said I needed a new battery after a fan assembly replacement...
The car runs fine until i turn on the lights, radio and air... then the car loses power and dies if i stop.
Any ideas what it could be before I take it back to the dealer and pitch a bitch?
The alternator should be able to supply enough current to run all rhe car's systems including accessories at the same time. If your battery is dying when they're on, the alternator isn't doing it's job. It is possible that a dying battery is also taxing the charge system into overload (not THAT possible though)... I suggest you take your car to a local major auto parts store - most will test your battery for free, and provide a replacement, if necessary, at 1/2 the cost of the dealer.
Sounds to me like the alternator. I'd go with Quadmaniac's advice and have it tested at the auto parts store. When testing they can also tell you if your alternator is working properly. The new battery the dealership installed got the car out of their shop but left you with a new problem. Was the car doing this when you took it in for the fan replacement? Also...the alternator could be working properly but not getting the juice back to the battery. BTW...nice looking car.
They may not have done a proper load test on the alternator. Maybe they checked the battery -- found it to be bad and thinking "its the most logical problem" replaced it. I have had alternators pass a basic test and then die days later - so this does happen. And its not uncommon for a failing alternator to stress an older battery to failure.
I have never replaced an alternator in any of my Jaguars -- even in the 80's - they are normally very reliable. But it sounds like you need one. And the battery from the dealer while a little $$ is a very good one.
Good luck
Good luck
This problem did not materialize until they replaced teh fan assembly
Often the best approach is to take your car to a shop that specializes in automotive electrical service and repair.
