power seats not working
Guest
Posts: n/a
Guest
Posts: n/a
first, make sure you check power seat fuse first, i remember power seat fuse right at below/front of rear seat cursion, u have remove panel at rear seat.
you can purchase any where at used park, but make sure you have check that module habe same part number. you can check part number inside drive side trunk, remove spare tire and you can see.
I have the same issue and need a replacement module. If someone can give me a link or a PM on the cheapest/best place to get one from. Mine is for an 03 XJ8. Additionally, unless it sticks when there is no power/module bad the switch on the side of the seat (driver's seat) is stuck in the position to slide the seat backwards. I may need new controls also if someone knows where to get them.
Thanks,
Mark
Thanks,
Mark
retromotors (01-30-2015)
Dick, what year/model? Assuming it's similar to mine, if when pressing the switch you hear a click from somewhere away from the switch, it is not the switch. It will be the motor, the Seat Control Module, or the wiring in between them. I believe you can swap Seat Contol Modules from left to right to determine which.
I won't try to answer because our cars may be different.
On my '98 YM, the cover for the fuse box in the trunk has the fuse layout diagrams for all 5 of the car's fuse boxes!![Icon Special](https://www.jaguarforums.com/forum/images/smilies/icon_special.gif)
Go figure!
Guess it's one of those ... "seemed like a good idea at the time."
Go figure!
