Power steering fluid?
I'm replacing my power steering pump soon and I'm confused about the type of power steering fluid that I need. The owner's manual says to use Dextron III but I can't find any Dextron III power steering fluid, only tranny fluid. I talked to the local O'Reilly's guys about it and they told me that "any of the power steering fluids should be fine". Are they right? If not, what's the correct fluid to use?
Power steering fluid is not correct.
If you cannot find Dexron III, then find ATF that is Dexron III compatible.
One example is Valvoline Maxlife Dex/Merc available at any Walmart:
Valvoline.com > Products > MaxLife > Automatic Transmission Fluid MaxLife > MaxLife® DEX/MERC ATF
badger2196 (10-01-2014)
1964Daimler
09-09-2015 11:28 AM
