Power Steering Noise
Today my car started making the old power steering moaning noise when turning the wheel at low speeds, like engine running in the garage, turn the wheel slightly, pump makes moaning noise. Fluid was low in the resirvoir, not on the dipstick, but visible in the container. I pulled out what I could that was in there and put in some new Prestone Dexon III to the full mark, started the engine and cycled the steering lock to lock about 8-10 times, same behavior and the resirvoir now shows foaming in there, which I think means I have air in the system.
Can I get the air out by simply driving and checking the fluid level or is there a bleed process to extract the air pockets? Or is it time to order a pump and probably some hoses that will likely break off as I do this? I'm assuming I must have a leaky hose fitting or seal somewhere or the fluid wouldn't have gone down this low as the system is closed loop, correct?
Steering effort is normal and light, just drove 300 miles today for work without issues...just the noise and the foam.
Thanks in advance.
Edit: This is an 01 XJR with 145k miles on it. Had it about 10 months now, I topped off the ps fluid last fall and checked it frequently for awhile after with no change in the level. Obviously I've now gone too long between checks.
Thanks in advance.
well..everything is possible but PS pump for X308 is not insanely expensive.so not sure if just getting a new(re-man) one will just make your own life easier and call it a day
Welp. Good news is my hoses all seem good. Bad news is the pump is leaking fluid out just sitting there, so new one ordered and will be here later this week.
Anyone have a R & R procedure handy? I saw some other old thread that said remove the pulley bolts before taking the belt off, but from there I'm a bit fuzzy. Hoses are self explanatory, but where are the mounting bolts? Seems weird that the pump has threaded holes, so I'm guessing some bracket must be in front of it?
Probably high time I got the JTIS downloaded and working on win10.
Aquifer, I'll have a look, thats sounds perfect for my needs.
This seems harder than it ought to be. The pulley bolts will not budge. 6 point socket and a foot ling ratchet just turns the motor with the belts.
Took the radiator fans out to make extra room and put my 1/4" impact on them. Killed a full 4amp/hour 18v battery, zero motion on any of the bolts. 1/2" impact won't fit.
Can this be done with the pulley on there? I'm thinking no. I soaked the bolt heads in penetrant and then tried to spritz some on the end of each bolt as well. Maybe some heat...nope. hit it with a bit of map gas and it did nothing, don't dare use too much heat as im sure to torch the garage.
Any suggestions?
Any suggestions?
I wonder if these bolts have threadlocker on them?
Edit:
So my impact gun is a 1/4" gun, more for driving screws than anything else...I think it provides maybe 100 ft-lb or so. I just ordered a stubby 3/8" cordless impact wrench (225ft-lb) that I'll pick up on my way home and try out tonight. I'll also consider hitting the bolt heads with my heat gun for awhile to potentially loosen any possible threadlock that might be in there...not crazy about the torch in that space as I'm sure I'll wind up breaking something I need.
Barring that, maybe a strap wrench will hold the pulley tight enough for me to put a 7' breaker on it? Are there any pulleys in there with a slot in them that I can lock with a screwdriver or something to keep the engine from spinning?
Edit:
New pump arrives today so hopefully this ought to be buttoned up tongiht. I have a couple quarts of Prestone synthetic Dexon III, is any Dexon III synthetic pretty much like any other or is there a compelling reason to stop and get a couple bottles of Mobil1 ATF or some other premium label? If it matters, I use the car year round in all temperatures.
Got it all wrapped up a short while ago. That old pump fought me every step of the way, but its done and the new pump works great. Moaned a bit at startup but it stopped once the fluid purged to last of the air bubbles (I hope). Only needed about a 1/2-2t3 quart of dex3, which tells me i did a lousy job of purging the old fluid.
Belt and I think tensioner pulley are squeeking a fair bit, bubitm certain i got penetrating oil all over the belt, so I'llput those items on my short list.
Anyone doing this, do yourself a favor and take the cooling fans out. You'll pick up some valuable space for your hands, just be very xareful of the hard lines on the left side of the radiator as I hear they're delicate abd hard to find replacement parts for.
Thanks everyone for the advice.
Jhartz (05-26-2023)
For anyone who stumbles across this thread later: I recommend taking the wheel off and removing the fender liner. It doesn’t give much extra room, but it allows you to see what you’re doing a little better. I took the lower pump bracket bolt out from that vantage point, and I loosened the lower pressure hose and spun it off with my fingers from the wheel well area too. For the upper supply hose, I took it off at the reservoir and it came out with the pump. I also recommend removing the fan shroud to have more room to work.
Something that amused me is that the workshop manual does not have a R&R procedure for the power steering pump. At least not that I could find anyway.
skinnypuppy_22
01-12-2017 10:03 AM
burmaz
03-22-2012 09:03 PM
