Power steering pump recommendation
Received 1,794 Likes
I'm not really sure what your suggestion that I do a search... Or even your link has anything to do with my question.. Did you even read my question or just assume I'm someone that doesn't do any research on my own..I have no problem finding numerous places that offer a pump for sale my question was not on where to find a pump but rather if anyone had any experience with any of the numerous rebuilding brands..I did do a search both on here and on yahoo and in fact came across your link.. Which just talks about where to buy one. Thank you for actually reading my short post before insisting I do a search.
Steve SOMERS (03-01-2022)
I did read all 17 words, its a remanned power steering pump for a car that is 15+ yrs old your asking for opinions on. In that thread Jhartz put in a good suggestion I thought, as also the possibility of going with a scrapyard. Anything you buy now, except from Jag, will be a reman, usually by Cardone, they do quite a bit of anything that can be remanned.
Yes I'm aware that cardone does most of the remaining I was hoping that maybe one of the other companies wasn't just relabeling but actually rebuilding them to a higher standard then cardone..I haven't had the best luck with them... At this point I'm hoping the pump is still fine I discovered someone replaced the suction hose with a generic soft hose.. I've ordered the correct hose and hopefully that'll fix that... I'll keep everyone posted
No need to get crumpy, surely not towards someone like Highhorse, who effortless posts to help others, not even if it is not the answer you were expecting.
Good luck solving your steering problem, hope the new hose will solve it.
