Precisely how bad did I *$^%# myself
BACKSTORY!...
In 2013 I bought a sweeeeeet '99 XJ8 with 86k miles for $2000.
I decided to be proactive and install a timing chain/tensioner kit preemptively.
Tore the perfectly good running 4.0 down. It was shockingly clean inside,and the original plastic tensioners weren't even cracked. After reassembling the engine, it never did start. Sounded like it had no compression. I tested cylinder one and got like 15-20 lbs.
After double checking all my work, which appeared to be fine, I pulled the passenger cylinder head off. I found no evidence of piston to valve contact.
Lost interest and abandoned the car at the back of my shop for two years.
Last week I got some ambition and started snooping around on the motor again.
I did find that my Cam phasers were turned all the way clockwise. I assumed that must be my problem, since I was finding sources claiming that they should be turned all the way counter-clockwise on assembly. I cranked them back to the left as far as they could go, and put the engine together again.
Now it has No compression at all.
HERE'S MY QUESTION-
Apparently I put the left cam on the right head and vise versa. Anybody else this stupid? How far up a creek am I?
HERE'S MY QUESTION-
No compression... had that before - thanks to what appeared to be a bore wash. Unsure if that can happen with what you have done here, but wondering if the same 'fix' would do the trick, i.e. tp of engine oil in each cylinder then crank up with gas peddle to the floor, slowly releasing... just a thought.
Chuck Schexnayder
33
10-24-2015 10:20 PM
