Premium sound system factory rest shelf sub replacement
Not sure if he's updated it, but this car audio list is spot-on or @ least it was.
Updating my good/bad/ugly list. come help! - ecoustics.com
Jennifer S Flavell (03-18-2016)
Charlzo...I am gonna see what they recommend amp wise for that speaker and if I don't like what they suggest I am thinking this little guy should do the trick.
Alpine MRV-M250 V-Power 250W Monoblock Amplifier
Or one of these with the 2 channels bridged
http://www.crutchfield.com/p_777M100....html?tp=35757
http://www.crutchfield.com/p_130GMA3....html?tp=35757
I haven't heard it. The speaker has been broken since I got the car. I am looking for a replacement for 2 reasons. 1. Getting to the speaker is a PITA and I don't want to deal with it and my installers aren't interested in removing the old and then having to repair it. They would remove it and install a replacement that fits though. 2. From reading posts about the OEM speaker it wasn't that great to begin with so if I can replace it with something better I want to go that route. I am not interested in any trunk mounted subs so please don't recommend I go that route either. I want something that will replace and fit in the original space that gives good bass and will be run on its own amp.
Vector
Received 1,797 Likes
Here's another speaker set to check out and they are really shallow and only 6.5"....
As for your amps your looking at, I have the earlier version of that Alpine 250, mines the 240 and I barely add any gain to it and it rocks the car with some nice sound. I got mine from Crutchfield also.
Jennifer S Flavell (03-19-2016)
#28
Vector
#31
![Icon Smile](https://www.jaguarforums.com/forum/images/smilies/icon_smile.gif)
You can actually see all that from the trunk area, looking at the speaker from the bottom, better?
Vector
#32
So the guy who was gonna sell me that set of CDT speakers backed out the deal, *******. Tis ok though cause I bought these direct from CDT
Shop CDT Audio - CL-69S
Charlzo is still gonna be my speaker buddy and it looks like he can swing by my place to pick his up on his return from vacation trip so we will have a meet and greet bonding over java and jag talk.
Always fun getting to meet forum members in person!
I also decided to go with the Alpine MRV-M250 amp to power it and picked one up on eBay for $65. So my equipment cost is at a measly $110
#33
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
Please report back if this model 6x9 sub turns out to be a drop-in replacement physically, and will clear the fuel tank under, and the grill on top, or if there are any installation lessons-learned otherwise.
Obviously this isn't a drop-in replacement electrically for the OEM sub and system, but I'm more curious about the physical fit at this point.
#34
Ok, just got it installed. It sounds fantastic. There was clearance above the gas tank, not much mind you but clearance none the same. Almost a drop in replacement. Had to widen the width a bit but was easily done with some hammer tapping...see pic. My original was not fixable....also see pic. So if you are looking for an after market replacement that can go in the factory hole this works! It won't upload more then one pic per post for me so 1st here is my blown factory speaker.
#35
#36
#37
New install looks great. I'm blown away (no puns intended) at how bad your factory was. I'm used to just seeing the foam disintegrate but the cone in pieces is just ouch!
Glad to hear it's in and sounds great, I'm about to fire up a ton of overtime at work, so I'm hoping to get to my own experiments over the next few weeks.
#38
Looks like this has been resolved. Late to the thread but for those who are reading "TB Speakers" has a model no. W69-1436 it is a 4 ohm direct plug and play replacement for an x305's, the x300's are the same gas tank set up. No trimming, bending or pounding necessary. www.tb-speaker.com
#39
