Problem with Camshaft VVT?
Old 08-05-2014, 08:57 AM
ericjansen's Avatar
Received 1,354 Likes on 928 Posts
Originally Posted by xjay8
Hey sam....I really can't see why this would be the problem....I think you're starting to clutch at straws ;o]
Yeah, I do agree, as I thought about it as well.
There should be a relation between the VVT operation (connected and operating / disconnected and not working) and the noise.
I also do not see how the chain tension should differ from those 2 situations.
Can the noise be traced back to any part of the VVT operation? Anyone with more knowledge about that?
Old 08-06-2014, 05:48 AM
blackhonor9's Avatar
I changed everything else except for timing chain and cam adjuster bracket. Receiving code P1384 which jaguar mechanic stated it could be the oil flow to the vet actuator or the actuator itself. Since I changed the vet actuator I thought just change the cam adjuster bracket also.
Old 11-01-2014, 05:44 PM
ericjansen's Avatar
Any more update on this one?
Eric
Old 11-02-2014, 11:33 AM
I removed the oil pan oil sump to clean them and also, I changed the VVT unit. It fixed the tapping issue now the motor jumps. I think I didn't set the timing correctly and the secondary timing chain tensioner is compromised so that needs changing as well.
Old 11-06-2014, 05:40 AM
ericjansen's Avatar
Take it easy, don't break her ...
Is it a hard job to change the VVT?
Any thought on WHY the VVT made this noise?
Eric
Old 11-07-2014, 09:10 AM
I'm not sure. I Changed it because it was the only other part that had not been changed.
Clamdigger
09-12-2015 03:43 PM
mcdutch
09-04-2015 03:38 AM
obwoodie
09-03-2015 07:45 PM
laserguy
09-03-2015 02:02 PM
Quick Reply: Problem with Camshaft VVT?
