Problem with my 2000 XJ8 VDP dashlights
I have an intermittant problem with my dash lights. Sometimes some of them do not come on. Other times they delay, then come on after some driving. Still other days, the ones under my tachometer do not come on. The fact that they all eventually come back on tells me that the bulbs are not bad. I have no idea what the problem could be. Is there a quick fix or is this something that could be a battery voltage problem? I know in the past, the car's electrical systems were VERY sensitive to fluctuations in the battery voltage.
I have to check my Jag and Mercedes this weekend for the same thing.
Good luck!
While you have the connector apart shoot some electrical cleaner in the connectors. It's not real hard to get to the dash pod connections, you just need to be sure you don't drop a screw, and be careful pulling the wood piece off. Oh, and it helps to move the steering wheel out of the way. There is stuff in the archives on this
KarimPA
09-12-2015 08:15 AM
