problems clearing abs codes
2000 XJ8 I replaced the abs pump for code c1095..bleed the brake system but couldnt clear the code...so i disconnected wheel speed sensor
2 create a code.n couldnt clear that either...ive used 3 of snap-on scanners and 2 other scan tools...they will talk to ABS but wont clear the codes....can anyone help me with this...ive disconnected the battery also!
