Programming key fob
#41
The following 2 users liked this post by ericjansen:
DimitrisBXL (03-10-2016),
Don B (03-27-2017)
#42
You might want to have a look at the XJ8 Owners Video, you might be in for a surprise or two
X308 XJ8 Owners Video - JagDocs.com Video Channel - YouTube
#43
#44
So I succeeded with this but only after many fails. Why the fails? Turns out after replacing my fob battery and going through the procedure multiple times, sometimes I'd see hints of progress and sometimes not. Here's why it kept failing. The lock and unlock buttons on my fob weren't working. So when I'd use them to program, no progress. And if I used another button, when I'd succesfully program I couldn't tell if I was only checking by trying to lock and unlock. The only way I got the programming to work was by using either the headlight or trunk release button. (I'm not sure which one I pushed.) And then testing it using one of those same buttons. So now I can pop my trunk and light my lights with my fob...but I still need a new fob. Hope that helps somebody.
#45
Don B (07-04-2024)
#46
#47
The car was in LEARNING MODE but..............
Is the keyfob transmitter actually sending a signal?
https://www.ebay.com/itm/17612411479...3ABFBMkNaUl41k
Many Auto parts stores have testers.
#48
#49
Remove the rubber button pad and really clean the rubber contact nubs under the buttons with denatured alcohol. Use a clean paper towel so you can see if any residue is removed. After fooling with just a light wipe of the nubs and not getting the fobs to work reliably, I tried this methind. Now all of my fobs work fine!
motorcarman (07-04-2024)
