Programming key fob
Old 03-10-2016, 06:10 PM
ericjansen's Avatar
Received 1,352 Likes on 927 Posts
Originally Posted by DimitrisBXL
Funny part is before I switch the batteries. every time I was knocking the car with the remotes. the seat, mirrors and steering wheel will reset their positions.
You might want to have a look at the XJ8 Owners Video, you might be in for a surprise or two .
The following 2 users liked this post by ericjansen:
DimitrisBXL (03-10-2016), Don B (03-27-2017)
  #42
Old 03-10-2016, 11:44 PM
DimitrisBXL's Avatar
X308 XJ8 Owners Video - JagDocs.com Video Channel - YouTube
I have it in my phone saved. I wanted to write unlocking and not knocking. I tried to re program the seat but it failed.
  #43
Old 03-11-2016, 06:42 PM
Received 8,138 Likes on 4,910 Posts
A simple search in the large file area...................
Here are some TSBs Again...........
bob
File Type: pdf
File Type: pdf
  #44
Old 09-03-2022, 07:41 AM
99 XJ VDP SC's Avatar
So I succeeded with this but only after many fails. Why the fails? Turns out after replacing my fob battery and going through the procedure multiple times, sometimes I'd see hints of progress and sometimes not. Here's why it kept failing. The lock and unlock buttons on my fob weren't working. So when I'd use them to program, no progress. And if I used another button, when I'd succesfully program I couldn't tell if I was only checking by trying to lock and unlock. The only way I got the programming to work was by using either the headlight or trunk release button. (I'm not sure which one I pushed.) And then testing it using one of those same buttons. So now I can pop my trunk and light my lights with my fob...but I still need a new fob. Hope that helps somebody.
  #45
Old 09-03-2022, 08:42 AM
Remove the rubber button membrane and clean the back side with alcohol and a cotton swab as well as the circuit board contacts.
You can usually get the transmitter to work with those buttons but they are the ones used most frequently so the contacts get worn.
Don B (07-04-2024)
  #46
Old 06-29-2024, 08:21 PM
vincent661983's Avatar
Changed the battery and fob didn't work now.
I followed the instruction. Car got the beep and the red light flashed once. So my car recognizes the fob But fob is not working?
what am i missing
  #47
Old 06-30-2024, 09:03 AM
The car was in LEARNING MODE but..............
Is the keyfob transmitter actually sending a signal?
https://www.ebay.com/itm/17612411479...3ABFBMkNaUl41k
Many Auto parts stores have testers.
  #48
Old 07-03-2024, 04:12 PM
now the FOB only works with LOCK and the LIGHT on, the unlock and trunk release are NOT working
  #49
Old 07-04-2024, 09:11 AM
David N. Warner's Avatar
Remove the rubber button pad and really clean the rubber contact nubs under the buttons with denatured alcohol. Use a clean paper towel so you can see if any residue is removed. After fooling with just a light wipe of the nubs and not getting the fobs to work reliably, I tried this methind. Now all of my fobs work fine!
motorcarman (07-04-2024)
JaguarXJL15
02-06-2024 12:23 PM
Peterinio
10-16-2019 09:54 PM
A.J.P
UK & Eire
01-27-2017 11:32 AM
Etobicoke sportwagon
02-23-2016 03:24 PM
redxk8
09-30-2015 08:18 AM
Quick Reply: Programming key fob
