Programming a TCM for an x308
hmm, althought I am a newbie in Jaguar universe, I understood it differently. I am under the impression the TCM adaptation needs to be reset (and relearned) if the TCM module come from another car or any work has been done on the transmission cluch packs. This is to adapt the shift diagrams to your particular gear box tolerances.
Also it is my understanding that AE with jaguar expansion is able to do that (on most model according information on their website).
Thank you for your answer.
I can tell you my problem.
My Transmission was damaged. So we decided to replaced the Transmission with one from a car with accident. The transmission from the car with accident was in very good condition.
After the conversion the transmission works no fine. If i put the gear from N to D their is a big bang. Also if i drive and break, their is a little bang when the gear select from 3rd to 2 nd gear. I dont know why, because the transmisson worked very fine before the conversion.
I think i have to adapt the TCM or have to drive a driving cycle for the TCM to learn the new tansmission.
I tried to put the TCM from the accident car in mine, but because the accident car has no cruise control, so my car shows with this TCM gearbox fault.
I hope you can help me.
Thanks for your help
Mesut
Mesut
There's no need to perform any adaptation on a TCM. If you remove a battery or a TCM fuse the TCM will re-learn very fast. I've rebuild mine transmission in march 2013, everything, except a case and output shaft was new (incl. torque converter, valve body and so on) - after a TCM reset it works fine.
If you have a bang when engaging in D or during shifting it indicates a problems with transmission or with an engine.
You should check LTFT and STFT readings, MAF readings and HO2S readings first. If there's something wrong - there'll be harsh shifts and other glitches. Actually mine LTFT/STFT were pretty bad, during a PCV malfunction. I suppose it was a primary cause of the transmission failure (broken A drum).
Hi Mesut
Do you have a XJ8 or XJR?
I am not sure for the XJ8 (not the same transmission) but the XJR has a mercedes transmission that does require an adaptation if any mechanical part is replaced (a fortiori if the entire transmission has been replaced or rebuilt).
I do not have it handy right now but I will extract the section on the mercedes transmission adaptation procedure from the JTIS tonight and look also for the XJ8 trans.
Cheers,
Bruno
Cheers,
Bruno
Simple way to reset the adaptation:
1. Turn the ignition key to the on (not start) position.
2. Press the gas pedal to the floor (depress kick down switch) and hold for 10-15seconds.
3. Turn the key to the "off" position (don't remove the key), then release the gas pedal.
4. Wait at least two minutes for ECU to reset.
Keep drivers door closed the entire time.
I have a XJ8. Today i was by a friend and changed my TCM with him. My TCM works very good in his car. His TCM shows the same problem in my car. So I think you are right. There is no adaptation by the XJ8. A reset doesent helps. Should it be that the garage which replaced the transmission did anythink wrong. I thing they filled not much oil in the transmission.
Have you another Idea how I can find my problem.
When I start my car in the morning, first theri are no bang when I put the gear from N to D. but after 30 seconds their is the same problem. But the problem is not by a colt start. So their is anithink when the transmission going warm.
Thanks for your aswers.
I bet that it's not a transmission issue. It's an engine management issue. Check fuel trims, MAF and HO2S readings. IIRC i've made a topic here about it.
And it is not a signs of a low fluid level - if the fluid level is low, the trans will be slipping.
UPD: it is here. https://www.jaguarforums.com/forum/x...01-xj8-103225/
Before i've fixed a leak i've had a harsh shifts and some bangs too
Hello, Their is no noise when I brake.
The Jaguar Garage found nothing.
Yesterday I tried somethink different. When I put the gear from N to D, their is a big bang, if I put the Gearvery quickly from R to D, their is a little bang. So i htought it could be a problem with my iddle speed.
I saw videos of other XJ8 in youtube. their iddle speed is less than my iddle speed. My iddle speed goes from 650 to 690.
Do you think it could be my iddle speed which causes the problem.
How can I correct my iddle speed.
Thank you for your help.
Just look at mine post. There's no way to adjust idle speed, it's adjusted by an ECU. If there's a vacum leak the idle, fuel trims and lambda will be messed.
One of the sympthoms is the slow RPM decrease after some revving.
The transmission will have that bang untill you'll fix an engine management, since a TCM sends a request to ECM to reduce torque before shifting gears. If there's something wrong with an engine management the available amount of torque is unexpected for a TCM and causes hard shift.
