Proper Sealant
Inside the cam cover, passenger side, there is a plate (plastic type) holding the metal meshes in place. It cam e loose so I removed all the sealant, which seems like glue/foam material. Very hard, and chip it away. Now I need to replace the sealant, have no idea what to use. Subject to heat, oil of course, but I know a flexible sealant wasn't used. Any help please. Seemed to be very rigid and brown (color could be from oil) although may set differently. Would any good sealant work?
bigcat777 (11-08-2015)
SD96XJ6L
01-19-2016 05:34 PM
