PSA : Cheap New Replacement FOBs
So I bit the bullet & gave this vendor a whirl, it programmed 1st attempt & included the battery already installed. It also has a smaller footprint for less bulk in the pocket, I deem this a win for sub $50.
https://www.ebay.com/itm/For-1998-19...5/352437842314
The following 10 users liked this post by King Charles:
CharlzO (10-19-2018),
dwgates (11-01-2018),
gerardbooth (09-04-2024),
Highhorse (10-19-2018),
IPBR21054 (07-26-2024),
and 5 others liked this post.
Received 1,813 Likes
Thanks KC, I was just talking to my Indy about this the other day...the $300 cost is a bit hard to swallow on a 19 yrs old car. That looks like the Ford fob, but I recall another member mentioning using the Ford one about a year or so ago, didn't see a follow up on if it was functional? I may just go ahead and do that myself,...gracias amigo. Did you get just the one or both?
Yea it synced up instantly & has great range thus far. I'd had a lot of issues w/ used OEMs w/ higher price tags, this is actually the 1st time I've had one program on the initial attempt lol.
I found he has a 2 fob purchase option also (which I got)... https://www.ebay.com/itm/352437840649 ...which is a few dollars off. I was down to my last fob and it was getting very intermittent again.
King Charles (10-20-2018)
LJA2610AA (or LJA2610CA, high sensitivity version) are for early X308's, using frequency of 315 MhZ. LJA2610BA (superseded by LJA2610BB) is for later X308's, using frequency of 433 MhZ. The part number and the frequency is written on the back of the fob. The remote sold on Ebay is good as a replacement for the early 315 MhZ remotes.
The following 2 users liked this post by M. Stojanovic:
nilanium (10-20-2018),
Phillythessp (07-02-2021)
The following 3 users liked this post by King Charles:
Both my fobs are marked on the back as LJA2610BB, and 433.92 Mhz. Mine is an early (September 1998) car, so should I have the early 315 Mhz. fobs? Could this be the reason I need to press 5 or more times to get the car to open/lock, or am I just having the same issue with fobs as everyone else? lol
Highhorse (11-04-2018)
One more question on the aftermarket fobs, are the buttons "clicky" switches, or a soft contact press like the OEM fob?
Maybe you had the SLCM replaced at some point with a newer model year one which ran on the newer frequency?
I received a great tip from ericjansen. I got a small piece of silver foil (stole it from the kitchen) and used a hole punch to make 4 small round pieces of foil. Put a small amount of GEL superglue on the back of each button (must be GEL superglue so it doesn't run all over the place and ruin the fob altogether). Carefully put the foil pieces on the back of the buttons, press down to seal onto the button and leave overnight to make sure they're really dry. Fit the fob back together. Did mine, works first time every time!
Paul
Paul
The following 2 users liked this post by euphonium01:
markdpeter (01-31-2022),
motorcarman (11-13-2018)
i programmed the two I bought while they were in my hand, while seated in the driver's seat, key in ignition. I don't see why the location of the FOB would matter, just easier to push the buttons when it wasn't attached to the key and behind the steering wheel.
I had seen something about programming multiple remotes at one sitting but elected to do mine one at a time. Not a lot going on in upstate NY so I have to pace myself!
Cant get mine to program, will continue to try tomorrow.
Contacted seller by chat at www.programtheremote.com and they recommended trying this but that didn't work for me either:
1. Enter the car and sit in the Drivers seat.
2. Place the key in the ignition.
3. Hold the headlight flasher arm back – the blue “high beam” light will come on the dashboard and the headlights will come on.
4. Keep holding the headlight flasher back and turn the ignition key to position 1.
5. Release the flasher, and then flash the headlights FOUR TIMES. You will hear a “Beep” AND/OR see a small red light illuminate briefly on the Gear Selector on the fourth flash of the headlight – this is to confirm that the car has entered programming mode.
6. Program each transmittor (up to FIVE fobs can be programmed) by pressing any button on the fob. You will hear a “Beep” AND/OR see the red light on the Gear Selector with each press of a button.
7. The car must “Beep” or red light flash five times to complete programming. Therefore, if you are only programming one transmitter you should operate the transmitter 5 times.If you are programming two transmitters you will operate one transmitter twice, and three times on the other.
8. Wait for the car to exit programming – this will be indicated by a final “Beep” AND/OR the red light on the Gear Selector.
9. The remotes are now ready to use.
